Out of Sync Items (need some help\advice )
Ver 1.18.6
3 nodes 1st - RW , 2nd 3rd - RO folder at all nodes fully sync, Global status match
only at node 3 “out of sync” from node 2
at node 3 i delete a file from “out of sync list” it rescan , ask to correct (due to RO) and it sync again, number of files “out of sync list” didn’t changed, this file still in the list.
action --reset-deltas at node 3 , didn’t help
I’m not certain about next actions to correct the error … need some help advice
Thanks,
Please post screenshots showing the Syncthing Web GUI on all affected devices. Logs with specific filenames which cannot be synced will be helpful too.
so …
I incorrectly run --reset-deltas command
It appears I should run it on the node where the discrepancy comes from
run it on node 2 does make the problem corrected.
