Out of Sync - generic error between Unraid and Synology
I’ve got Syncthing transfering data one way from my Unraid server to a Synology Diskstation. My initial sync worked ok. However, after some time I started getting an Out of Sync message on the Synology Diskstation on one of the files.
On the Diskstation I now have two files of 1760957 kb. One named .syncthing.2_CyberLinke_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe.tmp and the original file (that I manually copied over trying to get it to get it to consider it sync’d).
Looking for any insight on what I should do next. Appreciate any guidance.
I turned on model logging on both sides and I’m pasting the relevant pieces below:
Sending System: Unraid
2024-09-08 15:17:19 sendonly/q7u2h-z2qxu@0xc0003c5008 Scanning due to timer
2024-09-08 15:17:19 sendonly/q7u2h-z2qxu@0xc0003c5008 scanning
2024-09-08 15:17:22 model@0xc000002000 REQ(in): MCVC66G: "njz7w-hzq3f" / "Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe" o=1069547520 s=1048576 t=false
2024-09-08 15:17:22 readOffsetIntoBuf.ReadAt Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe read /data/software/Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe: input/output error
2024-09-08 15:17:22 model@0xc000002000 REQ(in) failed reading file (read /data/software/Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe: input/output error): MCVC66G: "njz7w-hzq3f" / "Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe" o=1069547520 s=1048576
2024-09-08 15:17:59 model@0xc000002000 REQ(in): MCVC66G: "njz7w-hzq3f" / "Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe" o=1069547520 s=1048576 t=false
2024-09-08 15:17:59 readOffsetIntoBuf.ReadAt Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe read /data/software/Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe: input/output error
2024-09-08 15:17:59 model@0xc000002000 REQ(in) failed reading file (read /data/software/Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe: input/output error): MCVC66G: "njz7w-hzq3f" / "Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe" o=1069547520 s=1048576
2024-09-08 15:19:17 progress emitter: bytes completed for 7yjtv-zgmsx: 0
Receiving System: Synology
2024-09-08 15:16:28 progress emitter: bytes completed for rahzk-acq4f: 0
2024-09-08 15:16:41 receiveonly/njz7w-hzq3f@0xc000948c08 need file Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe; copy 1, reused 1719
2024-09-08 15:16:41 progress emitter: registering njz7w-hzq3f Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe
2024-09-08 15:16:41 not weak hashing Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe. not enough changed %!f(int=00) < 25
2024-09-08 15:16:41 sharedPullerState njz7w-hzq3f Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe pullNeeded start -> 1
2024-09-08 15:16:41 model@0xc0003c4180 REQ(out): UBMNPTM (192.168.1.75:22000-192.168.1.45:22000/tcp-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P10-5VJ761TDTDC3E1CG7C83PBJBAU): "njz7w-hzq3f" / "Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe" b=1020 o=1069547520 s=1048576 h=535912d98cb1c2792b652e0d7afab02328f40b4a2f17bc5f14e470923d072713 wh=c90521a8 ft=false
2024-09-08 15:16:41 request: njz7w-hzq3f Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe 1069547520 1048576 UBMNPTM returned error: generic error
2024-09-08 15:16:41 receiveonly/njz7w-hzq3f@0xc000948c08 closing Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe
2024-09-08 15:16:41 receiveonly/njz7w-hzq3f@0xc000948c08 new error for Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe: finishing: pull: generic error
2024-09-08 15:16:41 progress emitter: deregistering njz7w-hzq3f Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe
2024-09-08 15:16:41 receiveonly/njz7w-hzq3f@0xc000948c08 changed 1 on try 1
2024-09-08 15:16:41 receiveonly/njz7w-hzq3f@0xc000948c08 copiers: 2 pullerPendingKiB: 32768
2024-09-08 15:16:42 receiveonly/njz7w-hzq3f@0xc000948c08 parent not missing Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe
2024-09-08 15:16:46 progress emitter: timer - looking after 2
2024-09-08 15:16:46 progress emitter: nothing new
2024-09-08 15:17:22 receiveonly/njz7w-hzq3f@0xc000948c08 need file Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe; copy 1, reused 1719
2024-09-08 15:17:22 progress emitter: registering njz7w-hzq3f Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe
2024-09-08 15:17:22 not weak hashing Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe. not enough changed %!f(int=00) < 25
2024-09-08 15:17:22 sharedPullerState njz7w-hzq3f Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe pullNeeded start -> 1
2024-09-08 15:17:22 model@0xc0003c4180 REQ(out): UBMNPTM (192.168.1.75:22000-192.168.1.45:22000/tcp-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P10-5VJ761TDTDC3E1CG7C83PBJBAU): "njz7w-hzq3f" / "Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe" b=1020 o=1069547520 s=1048576 h=535912d98cb1c2792b652e0d7afab02328f40b4a2f17bc5f14e470923d072713 wh=c90521a8 ft=false
2024-09-08 15:17:22 request: njz7w-hzq3f Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe 1069547520 1048576 UBMNPTM returned error: generic error
2024-09-08 15:17:22 receiveonly/njz7w-hzq3f@0xc000948c08 closing Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe
2024-09-08 15:17:22 receiveonly/njz7w-hzq3f@0xc000948c08 new error for Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe: finishing: pull: generic error
2024-09-08 15:17:22 progress emitter: deregistering njz7w-hzq3f Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe
2024-09-08 15:17:22 receiveonly/njz7w-hzq3f@0xc000948c08 changed 1 on try 2
2024-09-08 15:17:22 receiveonly/njz7w-hzq3f@0xc000948c08 copiers: 2 pullerPendingKiB: 32768
2024-09-08 15:17:22 receiveonly/njz7w-hzq3f@0xc000948c08 parent not missing Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe
2024-09-08 15:17:27 progress emitter: timer - looking after 2
2024-09-08 15:17:27 progress emitter: nothing new
2024-09-08 15:17:55 receiveonly/jfies-tcb4d@0xc0008d2008 finished scanning, detected 0 changes
2024-09-08 15:17:55 receiveonly/jfies-tcb4d@0xc0008d2008 next rescan in 57m30.006444315s
2024-09-08 15:17:59 receiveonly/njz7w-hzq3f@0xc000948c08 need file Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe; copy 1, reused 1719
2024-09-08 15:17:59 progress emitter: registering njz7w-hzq3f Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe
2024-09-08 15:17:59 not weak hashing Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe. not enough changed %!f(int=00) < 25
2024-09-08 15:17:59 sharedPullerState njz7w-hzq3f Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe pullNeeded start -> 1
2024-09-08 15:17:59 model@0xc0003c4180 REQ(out): UBMNPTM (192.168.1.75:22000-192.168.1.45:22000/tcp-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P10-5VJ761TDTDC3E1CG7C83PBJBAU): "njz7w-hzq3f" / "Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe" b=1020 o=1069547520 s=1048576 h=535912d98cb1c2792b652e0d7afab02328f40b4a2f17bc5f14e470923d072713 wh=c90521a8 ft=false
2024-09-08 15:17:59 request: njz7w-hzq3f Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe 1069547520 1048576 UBMNPTM returned error: generic error
2024-09-08 15:17:59 receiveonly/njz7w-hzq3f@0xc000948c08 closing Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe
2024-09-08 15:17:59 receiveonly/njz7w-hzq3f@0xc000948c08 new error for Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe: finishing: pull: generic error
2024-09-08 15:17:59 progress emitter: deregistering njz7w-hzq3f Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe
2024-09-08 15:17:59 receiveonly/njz7w-hzq3f@0xc000948c08 changed 1 on try 3
2024-09-08 15:17:59 Puller (folder "software" (njz7w-hzq3f), item "Cyberlink PowerDirector 11/2_CyberLink_PowerDirector11_ContentPack_Essential_G5_PCP120712-02.exe"): syncing: finishing: pull: generic error
2024-09-08 15:17:59 "software" (njz7w-hzq3f): Failed to sync 1 items
2024-09-08 15:17:59 Folder "software" (njz7w-hzq3f) isn't making sync progress - retrying in 1h6m0s.
2024-09-08 15:17:59 progress emitter: bytes completed for njz7w-hzq3f: 0
2024-09-08 15:17:59 model@0xc0003c4180 Completion(UBMNPTM-4K2NGNE-ZQAQT2Q-6LDUOOB-AF52JFM-UCPVPP2-TNWHIBI-GEB7BQ2, "njz7w-hzq3f"): map[completion:100 globalBytes:6362094859 globalItems:145 needBytes:0 needDeletes:0 needItems:0 remoteState:valid sequence:189]
2024-09-08 15:18:04 progress emitter: timer - looking after 2
2024-09-08 15:18:04 progress emitter: nothing new
Your storage is returning read errors to syncthing.
