Hi maintainers,
while working on a different open source project, I face the challenge of adding a “check” to GitHub that is automatically run on each commit. But if it fails, that should not mark the whole commit / PR as failed.
In the Syncthing main repo, we already have such “not required” checks running. Could someone with access to the repository settings please show how to set up such a distinction between required and optional checks? I think it will be under the branch protection settings, but could also need some YAML adjustments? Ideally with screenshots, please ![]()
I’m not very knowledgeable with GitHub CI in general. Others have already tried to find the settings, but so far no luck.
For reference: Type annotations in canopen · Issue #358 · christiansandberg/canopen · GitHub
Thank you very much in advance!
