I’d like to install syncthing on OSX and I want to use the launcher.
Syncthing starts correctly but when I try to use the web interface it displays “unknown device” and I don’t have an ID.
I’ve exactly followed the tutorial from the readme.
If I start the application by myself, everything works fine.
Do you run some funky browser extensions which block cookies, javascript or something?
I suggest you check the javascript console for errors, or try refreshing the page.
I only use adblock with safari. Chrome doesnt load the site at all.
With safari, the following console message appers every second:
[Error] Failed to load resource: Can’t establish the connection to the server. (events, line 0) in http://127.0.0.1:8080/rest/events?limit=1
Is there some sort of proxy involved?
Alternatively, are you sure that syncthing is still running after you’ve opened the page? You have to keep it running in the terminal (by nohup or disowning it or something).
Worst case, check stdout for crashes/clues.
May 21 16:54:43 83adfa75 com.apple.xpc.launchd[1] (net.syncthing.syncthing): This service is defined to be constantly running and is inherently inefficient.
May 21 16:54:43 83adfa75 com.apple.xpc.launchd[1] (net.syncthing.syncthing[69804]): Service could not initialize: 14B25: xpcproxy + 14045 [1344][1016C726-9ACF-3A24-9C51-A279F5C6B167]: 0xd
After the gui-request in the browser it says (I am not sure if it is interesting):
May 21 16:57:03 83adfa75 com.apple.xpc.launchd[1] (net.syncthing.syncthing): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
May 21 16:57:05 83adfa75.funky.hs-osnabrueck.de sandboxd[266] ([578]): storedownloadd(578) deny mach-lookup com.apple.webinspector
May 21 16:57:05 83adfa75.funky.hs-osnabrueck.de sandboxd[266] ([68940]): QuickLookSatelli(68940) deny mach-lookup com.apple.webinspector
May 21 16:57:05 83adfa75 com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
May 21 16:57:05 83adfa75.funky.hs-osnabrueck.de sandboxd[266] ([195]): softwareupdated(195) deny mach-lookup com.apple.webinspector
May 21 16:57:06 83adfa75 com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
May 21 16:57:06 83adfa75.funky.hs-osnabrueck.de sandboxd[266] ([578]): storedownloadd(578) deny mach-lookup com.apple.webinspector
May 21 16:57:06 83adfa75.funky.hs-osnabrueck.de sandboxd[266] ([68940]): QuickLookSatelli(68940) deny mach-lookup com.apple.webinspector
May 21 16:57:06 83adfa75.funky.hs-osnabrueck.de sandboxd[266] ([195]): softwareupdated(195) deny mach-lookup com.apple.webinspector
May 21 16:57:06 83adfa75.funky.hs-osnabrueck.de locationd[57]: NETWORK: requery, 0, 0, 0, 0, 11, items, fQueryRetries, 0, fLastRetryTimestamp, 453912279.9
May 21 16:57:07 83adfa75 kernel[0]: Sandbox: softwareupdated(195) deny mach-lookup com.apple.webinspector
May 21 16:57:07 83adfa75 com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
May 21 16:57:07 83adfa75.funky.hs-osnabrueck.de sandboxd[266] ([578]): storedownloadd(578) deny mach-lookup com.apple.webinspector
May 21 16:57:07 83adfa75.funky.hs-osnabrueck.de sandboxd[266] ([68940]): QuickLookSatelli(68940) deny mach-lookup com.apple.webinspector
Something is wrong with your launchd setup. Double check the paths in the syncthing.plist file; could be an incorrect setting of HOME or path to the binary…
“Install the syncthing binary in a directory called bin in your
home directory.” doesnt mean copy the complete syncthing folder into the bin directory
Always just copy this syncthing binary file into your bin folder!
Everything works fine now
Thank you all for your help!
