Zotero is a literature management program that stores attachments (web pages and pdfs) in folders with unique random names. It is possible to synchronize these folders directly:
For my application, I would like to do the same, but only propagate in one direction, from system A to system B. Folders directly added to B should stay on B, as there is not enough space on A. (Zotero db will be synchronized through something called a group library).
Sync conflicts should be rare, as the folder names are random, the only way to create a sync conflict is to add a pdf item to A, wait for it to propagate to B, and then modify it on B (e.g. by annotating), or by adding a further attachment on B. I don’t like this, but I could live with the issue if there is no other solution.
My current idea is:
- Set folder A to “Send Only”
- Set folder B to “Receive only”
- Would this work in principle? Any better ideas?
Zotero stores all attachments in a single folder. Another idea is to two-way sync A to B’ and then create hardlinks for all items in B’ to B.
Has anyone experience syncing Zotero? The storage folder contains thousands of files, some with UTF-8 filenames. I already got a warning that one filename was normalized. If syncing messes up some folders in an obscure way, it might take a long time to detect the issue and I might lose all entries added during that time, a risk I don’t want to take.
Is there a way to deal with the sync conflict described above? Is it possible to only sync changes back from B to A if the file is already on A?
If I accidentally press “Revert Local Changes” on B, it will delete all changes unique to B. This is a massive risk. Is there a way to disable this button?
I realize this is a bit of an obscure question, but maybe someone has a similar issue. Any pointers will be much appreciated!
