Folder X is hosted on a Linux desktop machine (device A) and is shared with two android devices (B and C). Folder Y is also hosted on A and is shared with B and C with the same settings. Devices B and C are stuck syncing X at 99% and have been for a couple of weeks now, despite the contents of X changing several times since then. However, both B and C are syncing changes with Y just perfectly.
The difference is about 2.5 MBs that B and C won’t sync. Scanning on A finds all the changes in X just fine. Rescanning on B and C doesn’t seem to do anything, as the last scan time is showing a couple of weeks ago on both, although at different times because the devices are not used constantly.
All three versions of syncthing are now 1.14.0. Device A was running a slightly older version that I then updated in an attempt to fix this issue. There are no ignore patterns set up, folders exist on all three devices and sync was working perfectly as expected until about three weeks ago on device C, about a week and a half on device B. A, B, and C are all on the same home network. No folder settings were changed before the sync issues began. X and Y are not subfolders of each other.
I’m new to syncthing issues, it’s always just worked for me, so I’m unfamiliar with what information may be needed. I’ll provide whatever is necessary. Thank you all.
–chriscrutch
