The error:
For the following folders an error occurred while starting to watch for changes. It will be retried every minute, so the errors might go away soon. If they persist, try to fix the underlying issue and ask for help if you can't. [ Support](https://forum.syncthing.net)
<mine> failed to setup inotify handler. Please increase inotify limits, see https://docs.syncthing.net/users/faq.html#inotify-limits
using various hints and tricks around the web, including the instructions above, I get here:
#su -c "sysctl -w fs.inotify.max_user_watches=1048576 && sysctl -p"
sysctl: permission denied on key "fs.inotify.max_user_watches"
root@65d4251087ce:/#cat /proc/sys/fs/inotify/max_user_watches
60553
root@65d4251087ce:/#cat /etc/sysctl.conf
fs.inotify.max_user_watches=3276800
so how can i fix my docker to support a larger set of files for watcher. this is after repeat attempts to alter the sysctl.conf to restart sysctl in place, to reboot, to whatever I always get the active watchers as ‘60553’.
thanks.
