I run 2 linux servers in two different locations that never talk to the internet.
When I built the first one it was connected, updates were run and this one has v1.22.3. running. I then built its mate using an offline mirror, this installed 1.18.1.
Both machines are not on the internet (and never will be). The v.1.22.3 has the options to send ownership, whereas the 1.18.1 doesn’t seem to have the same capabilities.
Both versions are running as root, however, the owner is not transferred across sites, a temp:temp user file is replicated as root:root which is not what I want.
How do I manually upgrade the 1.18.1 to 1.22.3 or even better both to 1.28.x
Many thanks Mattatat
