I don’t want to use https ssl self-signed certificate, how can I set up not to use https ssl certificate
You just need to replace two files within the Syncthing configuration directory. Namely https-cert.pem
and https-key.pem
. Be careful not to touch the other files cert.pem
and key.pem
, or you could lose your Syncthing device identity.
Or did you mean to disable HTTPS completely? That can be done under settings with just a click.
yes, i want disable HTTPS completely. where to set?
