One “advanced” configuration option that I need is a one-way “backup” that will copy a file to the destination (right) but then ignore any changes to it the file on the right after inital copy/sync.
For example, a file is created on the left, copies to the right. Great! But say I delete the same file on the right… is it possible to configure ST to NOT re-copy the same file to the right? But continue to copy any NEW files that are created on the left?
Read thru the Docs, but I didn’t see this anywhere. Just wondering before I get started on this. I THOUGHT this was a pretty simple feature, as I’ve used software that does this in the past, but recently I’ve tried a couple other software platforms, and they gave me responses like “WTF, why would you want to do this?”
Send only folder and ignoreDeletes are the only options available. If after reading the docs you think you can’t set it up, then probably you can’t.
In the scenario you’ve described, as soon as a file that was deleted on the right gets modified on the left, it would be resurrected back on the right.
I’m still a BIT confused by this text from the doc:
“Bob (Folder A) may continue to see Alice (Folder B) as up to date until the next time Syncthing is restarted on his device. // Should Bob (Folder A) modify any of the files that Alice (folder B) has deleted, the update will be sent to Alice and Alice will download the now updated file.”
Am I correct in assuming that if file.txt is changed or modified in any way in folder A (Bob) then the file is then re-copied?
Yes, if A modifies files after it was deleted on B, it will be resurrected on B.
If you really want B not to get that file ever again, add it to ignores.
