No UPnP device detected Issue
Hello!
I am trying to run Syncthing on a desktop Ubuntu (14.04) at my workplace. I have tried to connect it both to an Android smart-phone and to a Windows 8 laptop. However, it replies:
[monitor] 17:17:45 INFO: Starting syncthing
[IVEPE] 17:17:46 INFO: syncthing v0.11.24 "Aluminium Ant" (go1.4.2 linux-amd64 default) unknown-user@syncthing-builder 2015-09-06 06:47:52 UTC
[IVEPE] 17:17:46 INFO: My ID: IVEPECL-X26XXHF-J4JSK5V-TRSSGPM-DYMD75U-TGPLHHB-O2UAAWI-ANJZOQQ
[IVEPE] 17:17:46 INFO: Local networks: 127.0.0.1/8, 10.92.0.197/16, ::1/128, fe80::92b1:1cff:fe65:1ba5/64
[IVEPE] 17:17:46 INFO: Database block cache capacity 63516 KiB
[IVEPE] 17:17:46 OK: Ready to synchronize alexandria (read-write)
[IVEPE] 17:17:46 OK: Ready to synchronize caldera (read-write)
[IVEPE] 17:17:46 INFO: Starting web GUI on http://127.0.0.1:8384/
[IVEPE] 17:17:46 INFO: Completed initial scan (rw) of folder caldera
[IVEPE] 17:17:46 INFO: Completed initial scan (rw) of folder alexandria
[IVEPE] 17:17:46 INFO: Starting local discovery announcements
[IVEPE] 17:17:46 INFO: Starting global discovery announcements
[IVEPE] 17:17:46 INFO: Device BL72VQI-ODIDUXF-T46MEAF-DK3X3JX-TWG2WZG-GARU4GU-CETZ4EK-MGTXHAY is "grimsvotn" at [dynamic]
[IVEPE] 17:17:46 INFO: Device GNY6BTG-7MCZLTM-USGMHA5-ALA4K2Q-75YMK2S-BUYBGGL-YU6UJS5-UDYQAAA is "tamu" at [dynamic]
[IVEPE] 17:17:46 INFO: Device IVEPECL-X26XXHF-J4JSK5V-TRSSGPM-DYMD75U-TGPLHHB-O2UAAWI-ANJZOQQ is "prigogine" at [dynamic]
[IVEPE] 17:17:46 INFO: Starting usage reporting
[IVEPE] 17:17:46 INFO: API listening on 127.0.0.1:8384
[IVEPE] 17:17:56 INFO: No UPnP device detected
I have also tried
STTRACE=upnp syncthing
but it does not work either. I obtain the following log:
[monitor] 2015/09/09 17:21:36.653644 monitor.go:94: INFO: Starting syncthing
[IVEPE] 2015/09/09 17:21:36.977584 main.go:475: INFO: syncthing v0.11.24 "Aluminium Ant" (go1.4.2 linux-amd64 default) unknown-user@syncthing-builder 2015-09-06 06:47:52 UTC
[IVEPE] 2015/09/09 17:21:36.977685 main.go:476: INFO: My ID: IVEPECL-X26XXHF-J4JSK5V-TRSSGPM-DYMD75U-TGPLHHB-O2UAAWI-ANJZOQQ
[IVEPE] 2015/09/09 17:21:36.978966 main.go:586: INFO: Local networks: 127.0.0.1/8, 10.92.0.197/16, ::1/128, fe80::92b1:1cff:fe65:1ba5/64
[IVEPE] 2015/09/09 17:21:36.979101 main.go:772: INFO: Database block cache capacity 63516 KiB
[IVEPE] 2015/09/09 17:21:36.992999 model.go:194: OK: Ready to synchronize alexandria (read-write)
[IVEPE] 2015/09/09 17:21:36.994958 model.go:194: OK: Ready to synchronize caldera (read-write)
[IVEPE] 2015/09/09 17:21:36.995017 main.go:827: INFO: Starting web GUI on http://127.0.0.1:8384/
[IVEPE] 2015/09/09 17:21:36.996203 rwfolder.go:331: INFO: Completed initial scan (rw) of folder caldera
[IVEPE] 2015/09/09 17:21:37.007296 rwfolder.go:331: INFO: Completed initial scan (rw) of folder alexandria
[IVEPE] 2015/09/09 17:21:37.285212 main.go:904: INFO: Starting local discovery announcements
[IVEPE] 2015/09/09 17:21:37.286921 main.go:909: INFO: Starting global discovery announcements
[IVEPE] 2015/09/09 17:21:37.287559 main.go:689: INFO: Device BL72VQI-ODIDUXF-T46MEAF-DK3X3JX-TWG2WZG-GARU4GU-CETZ4EK-MGTXHAY is "grimsvotn" at [dynamic]
[IVEPE] 2015/09/09 17:21:37.287642 main.go:689: INFO: Device GNY6BTG-7MCZLTM-USGMHA5-ALA4K2Q-75YMK2S-BUYBGGL-YU6UJS5-UDYQAAA is "tamu" at [dynamic]
[IVEPE] 2015/09/09 17:21:37.287709 main.go:689: INFO: Device IVEPECL-X26XXHF-J4JSK5V-TRSSGPM-DYMD75U-TGPLHHB-O2UAAWI-ANJZOQQ is "prigogine" at [dynamic]
[IVEPE] 2015/09/09 17:21:37.287743 usage_report.go:154: INFO: Starting usage reporting
[IVEPE] 2015/09/09 17:21:37.287759 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on eth0
[IVEPE] 2015/09/09 17:21:37.287777 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on eth0
[IVEPE] 2015/09/09 17:21:37.287843 upnp.go:190: DEBUG: Sending search request for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on eth0
[IVEPE] 2015/09/09 17:21:37.287855 upnp.go:200: DEBUG: Listening for UPnP response for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on eth0
[IVEPE] 2015/09/09 17:21:37.287879 upnp.go:190: DEBUG: Sending search request for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on eth0
[IVEPE] 2015/09/09 17:21:37.287899 upnp.go:200: DEBUG: Listening for UPnP response for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on eth0
[IVEPE] 2015/09/09 17:21:37.304707 gui.go:221: INFO: API listening on 127.0.0.1:8384
[IVEPE] 2015/09/09 17:21:47.287987 upnp.go:221: DEBUG: Discovery for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on eth0 finished.
[IVEPE] 2015/09/09 17:21:47.288064 upnp.go:221: DEBUG: Discovery for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on eth0 finished.
[IVEPE] 2015/09/09 17:21:47.288140 upnpsvc.go:46: INFO: No UPnP device detected
Could you help me please?
Thank you very much!
It’s fairly unusual for a corporate environment to have upnp enabled, so I wouldn’t worry about this. If your actual issue is that stuff doesn’t connect I suggest looking into your firewalls and so on.
Thank you very much for your answer.
I am doing my best, but Syncthing still does not work. I apologize if my answers are silly.
I have opened the firewall ports according to Firewall Setup — Syncthing documentation . I used UFW (for the first time), and running
utf status
I get
Status: active
Logging: on (low)
Default: deny (incoming), allow (outgoing), disabled (routed)
New profiles: skip
To                         Action      From
22                         ALLOW IN    Anywhere
22000/tcp                  ALLOW IN    Anywhere
21025/udp                  ALLOW IN    Anywhere
21026/udp                  ALLOW IN    Anywhere
22 (v6)                    ALLOW IN    Anywhere (v6)
22000/tcp (v6)             ALLOW IN    Anywhere (v6)
21025/udp (v6)             ALLOW IN    Anywhere (v6)
21026/udp (v6)             ALLOW IN    Anywhere (v6)
Is it alright?
what else should I check?
I have been looking for already raised similar issues since yesterday, but nothing works.
Thank you
This is local firewall. I assume you are in some company evironment in which case you also need to get port forwarding setup on the router, as per the same guide.
Thank you for your help. I cannot solve the problem, but at least I have learnt something.
Version 0.12 will include relay support which should provide a solution to your problem.
That sounds fantastic. Do you have any rough estimate of when version 0.12 is going to be released?
there is beta1 out Release v0.12.0-beta1 · syncthing/syncthing · GitHub you could test that :wink:
