When connected to my university network, my PC cannot synchronize with my remote machine, despite the log shows that my PC is connected to a relay (see log below). Do I miss something when reading the log? What could I do (I have little action possible on the university network)?
If connected not to my university network but through my smartphone’s 4G, the sync runs well. Both my PC and my remote machine run Syncthing 1.18.4.
Thank you for the help!
Logs - click to expand
15:10:14 INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) shutting down
15:10:14 INFO: QUIC listener ([::]:22000) shutting down
15:10:15 INFO: TCP listener ([::]:22000) shutting down
15:10:15 INFO: Exiting
[monitor] 15:10:15 INFO: Log output saved to file "C:\Users\Héloïse\AppData\Local\Syncthing\syncthing.log"
[start] 15:10:15 INFO: syncthing v1.18.4 "Fermium Flea" (go1.17.2 windows-amd64) teamcity@build.syncthing.net 2021-10-24 14:50:30 UTC
15:10:16 INFO: My ID: ABCDE
15:10:17 INFO: Single thread SHA256 performance is 257 MB/s using minio/sha256-simd (242 MB/s using crypto/sha256).
15:10:17 INFO: Hashing performance is 185.04 MB/s
15:10:17 INFO: Overall send rate is unlimited, receive rate is unlimited
15:10:17 INFO: Using discovery mechanism: global discovery server https://discovery.syncthing.net/v2/?noannounce&id=LYXKCHX
15:10:17 INFO: Using discovery mechanism: global discovery server https://discovery-v4.syncthing.net/v2/?nolookup&id=LYXKCHX
15:10:17 INFO: Using discovery mechanism: global discovery server https://discovery-v6.syncthing.net/v2/?nolookup&id=LYXKCHX
15:10:17 INFO: Using discovery mechanism: IPv4 local broadcast discovery on port 21027
15:10:17 INFO: Using discovery mechanism: IPv6 local multicast discovery on address [ff12::8384]:21027
15:10:17 INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) starting
15:10:17 INFO: Ready to synchronize "Default Folder" (default) (sendreceive)
15:10:17 INFO: Ready to synchronize "DocSynchro" (p4dro-dkgtj) (sendreceive)
15:10:17 INFO: TCP listener ([::]:22000) starting
15:10:17 INFO: GUI and API listening on 127.0.0.1:8384
15:10:17 INFO: Access the GUI via the following URL: http://localhost:8384/
15:10:17 INFO: My name is "local"
15:10:17 INFO: Device WXYZ is "remote" at [dynamic]
15:10:17 INFO: Completed initial scan of sendreceive folder "Default Folder" (default)
15:10:17 INFO: QUIC listener ([::]:22000) starting
15:10:18 INFO: quic://0.0.0.0:22000 detected NAT type: Not behind a NAT
15:10:18 INFO: quic://0.0.0.0:22000 resolved external address quic://157.159.45.28:22000 (via stun.syncthing.net:3478)
15:10:21 INFO: UPnP parse: Get "http://192.168.0.1:1900/gatedesc.xml": dial tcp 192.168.0.1:1900: connectex: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée.
15:10:23 INFO: UPnP parse: Get "http://192.168.0.1:1900/gatedesc.xml": dial tcp 192.168.0.1:1900: connectex: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée.
15:10:27 INFO: Completed initial scan of sendreceive folder "DocSynchro" (p4dro-dkgtj)
15:10:28 INFO: Detected 0 NAT services
15:10:45 INFO: Joined relay relay://141.14.27.100:443
