Besides my problem with my ubuntu machine now my Android restarted with the newest Security Patch from google and directly told me, the SD card was damaged…
So, I reformatted the card and now Syncthing says it has no permissions to
‘mkdir /storage/A8C4-13F6/Android/media/com.nutomic.syncthingandroid’
The permission is denied…
I was so happy that /media/ worked and my Gallery and VLC found the data I was syncing. If it is in /data/ again, the files won’t be accessible to other apps, right?
Just guessing: Maybe it’s not allowed to create that directory but can write inside it, i.e. you’ll first need to create that directory. Worth a try maybe.
In Adnroid 11, apps can access (and write to) their own dirs both in data and media. But, in some way, no Apps are allowed to list the data directory anymore. My file manager app cannot access /storage/emulated/0/Android/data, but syncthing can write to /storage/emulated/0/Android/data/com.nutomic.syncthingandroid. So to access the synced files from any app, I had to change all the folders to .../media/....
