I’m trying to make the GUI accessible over https://sub.example.com/syncthing
Visiting the URL just ends up in missing Javascript and CSS.
Please help, I have been trying to solve this for a few days, no idea why it doesn’t work…
I can access the interface with https://example.com:8384
just fine.
Examples of what the Firefox console says:
The script from “https://sub.example.com/vendor/fancytree/jquery.fancytree-all-deps.js” was loaded even though its MIME type (“text/html”) is not a valid JavaScript MIME type.
and
Loading failed for the <script> with source “https://sub.example.com/vendor/angular/angular.js”.
Curling either of them returns 404 Not Found. Here is my nginx site config:
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
server_name sub.example.com;
set $base /var/www;
# SSL
ssl_certificate /etc/letsencrypt/live/example.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/example.com/privkey.pem;
ssl_trusted_certificate /etc/letsencrypt/live/example.com/chain.pem;
# reverse proxy
location /syncthing {
root $base/syncthing;
proxy_set_header Host $host;
proxy_set_header Referer https://syncthing:8384;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_pass https://syncthing:8384/;
proxy_read_timeout 600s;
proxy_send_timeout 600s;
# additional config
include nginxconfig.io/general.conf;
# HTTP redirect
server {
listen 80;
listen [::]:80;
include nginxconfig.io/letsencrypt.conf;
location / {
return 301 https://sub.example.com$request_uri;
docker-compose.yml:
version: '3'
services:
nginx:
image: nginx:latest
container_name: nginx-0
networks:
- web
ports:
- "80:80"
- "443:443"
restart: always
volumes:
- ./www:/var/www
- ./syncthing/config:/var/www/shh/syncthing
- ./nginx/:/etc/nginx
- ./nginx/log:/var/log/nginx
- ./letsencrypt:/etc/letsencrypt
- /etc/localtime:/etc/localtime:ro
- /var/run/docker.sock:/tmp/docker.sock:ro
command: "/bin/sh -c 'while :; do sleep 6h & wait ${!}; nginx -s reload; done & nginx -g \"daemon off;\"'"
syncthing:
image: linuxserver/syncthing
container_name: syncthing-0
networks:
- web
- st
ports:
#webUI
- 8384:8384
#listening
- 22000:22000
#port discovery
- 21027:21027/udp
restart: always
volumes:
- ./syncthing/config:/config
- ./syncthing/data:/data
environment:
- TZ=CET
- UMASK_SET=<022>
- PUID=1002
- PGID=999
networks:
web:
st:
As for the rest of my config (specifically nginx.conf
, and nginxconfig.io/general.conf
), you can look here
