### Does your log mention database corruption?
No
### Versions
- macOS⌠14.3 â _I believe this may be the key factor_ (also tested up to 14.4 dev beta3 23E5196e)
- syncthing ~~1.27.2~~ 1.27.3 macOS Bundle, also tested on v1.27.4-rc.1
### Setup
- 2 computers, both macOS + same versions of everything
- Both computers on the same LAN and have good connectivity
- 1 single Sync folder: 113,028 files, 20,458 directories, ~18.6 GiB
- ~~Trash Can~~ Simple file versioning (also tested with File Versioning disabled, makes no difference)
### Issue
In the last few days, while working in one particular subfolder of my single Sync directory, I experienced a situation where a deleted folder from machine A (that was present and fully synced between my 2 computers) almost immediately **re-appears**.
The error message `syncing: delete dir: file modified but not rescanned; will try again later` seems to repeat ad infinitum in the logs below.
The only way I "solved" this was to very quickly delete the folder at the same time from both machines. But, if I re-create that folder and then delete it from machine A or B independently, the problem resurfaces.
The clocks are set correctly on both machines.
Deleting the directory via Terminal `rm -rf ./whatever/` behaves the same as trashing it via Finder.
probably related forum thread: https://forum.syncthing.net/t/deleted-folders-keep-re-appearing/19290/28
**update**: PR submitted https://github.com/syncthing/syncthing/pull/9424
### Logs
<details><summary>(click to reveal)</summary>
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/parallel"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests/src/block_docstring"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/_utils"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/gapi/render/ocv"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/ma/tests"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/lib/tests/data"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests/src/size"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests/src/f2cmap"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/distutils/mingw"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/videoio_registry"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/gapi/ie/detail"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/typing/tests/data/reveal"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/random/lib"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests/src/string"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/src"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/typing/tests/data/misc"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/segmentation"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests/src/return_logical"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/distutils/checks"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/core/tests/examples/limited_api"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/core/include/numpy/random"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/typing"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/gapi/wip/gst"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/linalg/tests"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/compat/tests"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/ogl"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/distutils/tests"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests/src/regression/gh25337"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests/src/mixed"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests/src/cli"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/samples"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/typing/tests/data/pass"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/utils/nested"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/gapi/core/cpu"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/_core"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/gapi/ov"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/aruco"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/bin"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests/src/kind"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/ml"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/detail"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/barcode"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests/src/parameter"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests/src/quoted_character"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/gapi/oak"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/data"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/fft/tests"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/mat_wrapper"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/ocl"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/Error"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/random/_examples/cffi"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/gapi/core/fluid"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests/src/return_character"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/_backends"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/utils/fs"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/gapi/video"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/testing/_private"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 "Sync" (9bupw-pod9e): Failed to sync 106 items
2024-01-26 14:05:49 Folder "Sync" (9bupw-pod9e) isn't making sync progress - retrying in 1m1s.
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/distutils/__pycache__"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/matrixlib/tests"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/dnn"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/typing/tests/data/fail"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/gapi/onnx/ep"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/random/_examples/numba"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/gapi/own/detail"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/.dylibs"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/opencv_python-4.9.0.80.dist-info"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/random/tests/data"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/core/tests/examples/cython"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/misc"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/tests"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests/src/abstract_interface"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/ipp"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/flann"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests/src/crackfortran"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/testing/tests"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests/src/common"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/gapi/wip/onevpl"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/gapi/imgproc/fluid"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests/src/return_integer"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests/src/return_complex"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/_typing"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests/src/negative_bounds"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests/src/assumed_shape"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/_pyinstaller"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests/src/return_real"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests/src/callback"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/fisheye"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/gapi/streaming"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests/src/value_attrspec"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/core/tests/data"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/distutils/fcompiler"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/array_api/tests"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/gapi/core/ocl"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/distutils/command"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy-1.26.3.dist-info"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/doc"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/.dylibs"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/gapi/wip/draw"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/gapi/ot/cpu"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/cuda"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/polynomial/tests"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests/src/isocintrin"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests/src/module_data"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/core/lib/npy-pkg-config"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/random/_examples/cython"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests/src/array_from_pyobj"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:49 Folder "Sync" (9bupw-pod9e) isn't making sync progress - retrying in 1m0s.
2024-01-26 14:05:50 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z/numpy/distutils/tests"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:50 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z/numpy/core/include/numpy"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:50 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z/cv2/gapi/own"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:50 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z/cv2/gapi/ot"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:50 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z/cv2/gapi/onnx"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:50 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z/cv2/gapi/ie"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:50 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z/cv2/data"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:50 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z/numpy/distutils/fcompiler"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:50 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z/numpy/compat/tests"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:50 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z/cv2/utils"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:50 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z/cv2/misc"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:50 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z/cv2/mat_wrapper"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:50 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z/cv2/gapi/wip"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:50 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z/numpy/core/tests"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:50 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z/numpy/_utils"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:50 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z/cv2/gapi/render"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:50 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z/cv2/gapi/imgproc"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:50 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z/numpy/distutils/command"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:50 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z/cv2/typing"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:50 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z/cv2/gapi/core"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:05:50 "Sync" (9bupw-pod9e): Failed to sync 20 items
2024-01-26 14:05:50 Folder "Sync" (9bupw-pod9e) isn't making sync progress - retrying in 1m0s.
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z/cv2/gapi"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/typing/tests"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z/numpy/core"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/typing"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/matrixlib"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/lib"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/core/lib"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/gapi/ot"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/gapi"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z/numpy"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/typing/tests/data"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/random/tests"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/fft"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/core/include"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/compat"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/gapi/wip"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/gapi/render"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/ma"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/distutils"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/core"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/utils"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/gapi/ie"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/polynomial"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/linalg"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/core/tests/examples"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/core/include/numpy"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/gapi/own"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/array_api"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/gapi/onnx"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z/numpy/core/include"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/testing"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/random/_examples"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/lib/tests"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/core/tests"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/gapi/core"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z/numpy/compat"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z/cv2"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/random"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.z/numpy/distutils"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests/src/regression"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/numpy/f2py/tests/src"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 Puller (folder "Sync" (9bupw-pod9e), item "Settings/Alfred/Alfred.alfredpreferences/workflows/user.workflow.DBB851BA-9EFB-4042-950E-441689B493EE/libs.x/cv2/gapi/imgproc"): syncing: delete dir: file modified but not rescanned; will try again later
2024-01-26 14:06:49 "Sync" (9bupw-pod9e): Failed to sync 48 items
2024-01-26 14:06:49 Folder "Sync" (9bupw-pod9e) isn't making sync progress - retrying in 1m0s.
</details>
