Need Help, I Don't Know what to Do.
After making space in OneDrive due to it being almost full, by moving things to a thumb drive. I received these errors. A first error similarly appeared in the Camera folder, and it stopped syncing with the app on my phone. Now both folders have the error and state out of Sync, and I don’t know how to fix it. I am not very techy, so if someone could walk me through how to fix this, it would be greatly appreciated. Please help.
Looks a lot like your C: drive is full. I would strongly urge you to make some room on it — at least 100 MB or more — before Windows becomes unstable. Windows loses its mind when it cannot write to the C: drive.
Anything you can move off of C: or delete without missing it should be dealt with ASAP.
If that doesn’t fix Syncthing, I’ll be more than happy to work with you on that issue.
Okay, I will do that now
I got space on my C: Drive it took some time to find, but it was BG3 taking up all that space, so I deleted the game off the drive, and space opened up, but now it seems stuck on 95% Synced on PC and 99% on Android, respectively
Okay I fixed the second issue only to run into a 3rd when I open my files nothing has been synced and everything on Syncthing is green saying things are good to go but again nothing Synced
Here is the notice I got after playing around with the files to try and fix the error some more.
Please check your folder paths in Syncthing. I think we’ve had a similar issue recently, where the user put " quotes in the paths, which caused similar errors. Paths in Syncthing should be unquoted, so if you have " in there, please remove them.
Also, as someone who also mixes Syncthing with OneDrive (which we use at work), I would advise caution, especially if you utilise the OneDrive’s placeholder functionality (where files are only downloaded on demand when you click them, or otherwise they take 0 bytes on the disk). Syncthing doesn’t know how to deal with those, so to be safe, I always set OneDrive to download and store everything locally.
Okay I tried your suggestion and playing around with it some more but there is still no change. I do not know what I am doing wrong.
What is the problem right now? In the screenshot, there are no more errors and everything appears normal.
Exactly everything looks fine but I go to open the app on my computer and the changes I made to files in android are not synced and I can’t get them to Sync no matter what I do and everything appears normal on Syncthing front.
Could you also please share the same kind of screenshot from SM-A546U? Please take the screenshot from the Web GUI with expanded folder “Obsidian Vault” and expanded device “DaijaPC”.
Is this what you need?
or this
We need to to see the folder information on the Android side. At the moment, it seems that you scrolled down too much.
Also, are you still using the official Android app by any chance? Your Syncthing version is old. If possible, I would suggest switching to Syncthing Fork (see https://github.com/Catfriend1/syncthing-android#switching-from-the-deprecated-official-version for detailed instructions).
I don’t know what version I am using anymore, I just used what works let me get you that android information
here is the android stuff from the WEB GUI
So I transferred from The Old Syncthing on my Android to Syncthing-Forked but I had trouble with importing and exporting from the old one to another and I tried that a few times to no avail so I did it manually and got this fun error.
I somehow fixed the new issue that popped up and as that was fixed the main issue at hand which was I wasn’t getting my files to sync properly after following all suggestions and going in and manually deleting files that were labeled at conflict following the prompt. Thank you so much for your time
