Whaytom
September 20, 2015, 2:18pm
#1
Hey guys
I have recently installed Syncthing (current version: 0.11.25) on my Synology DS215j. It is fairly low powered (DualCore 800MHz, 512MB Ram) so i expected the inital sync to be slow. But I hoped it would speed up afterwards.
My Plan is to use my NAS as a central point to sync my PC and my Laptop. That way these two sync even if I do not have both powered on at the same time.
My Projects folder I want to Sync has ~100k Files which are 150GB total. The initial sync took ~30h. But even afterwards the cpu usage of my NAS stayed at 100%… My PC is turned on, but no file in the synched directory is changing.
Why is this happening? I already set the rescan Intervall to 6000s. I do not expect any files to change directly on the Nas, just via syncing.
I figured I might be able to use a Raspberry Pi 2 as my central Syncthing instance. Would this work better? It would still store the files on my nas via lan. I would have to buy one, so I can’t check yet.
Also I noticed the status indicator for my synced folder was broken during the initial sync. I had both webinterfaces closed (in hopes of speeding up the process). Whenever I opened the interface on my nas, it showed status “unknown” for my synced folder and listed 0 Files. It took a few minutes to show anything. This made tracking the process quite annoying.
Thanks for any help!
Whaytom
Arneko
(Arne Ko)
September 20, 2015, 2:23pm
#2
Change the ping-timeout to a higher value. In advanced settings (Action->Advanced or similar)
We should really open a troubleshooting guide I guess.
Whaytom
September 21, 2015, 8:43pm
#3
There were a few Ping Timeout before. I have now raised the Timeout limit to 600s and am not getting any timeouts. But the Problem remains.
I enabled debugging to see what syncthing is doing.
For about an Hour it is like this:
[CARWN] 2015/09/21 20:22:11.382058 set.go:93: DEBUG: Projekte Update(SXH6KAV-GARHFRL-WQ45IPL-KUA6LMZ-ZFAPW5Z-A322H4B-7TV5ISK-XLHHSQP, [1000])
[CARWN] 2015/09/21 20:22:13.420612 model.go:533: DEBUG: model@0x11d4df40 IDXUP(in): SXH6KAV-GARHFRL-WQ45IPL-KUA6LMZ-ZFAPW5Z-A322H4B-7TV5ISK-XLHHSQP / "Projekte": 1000 files
[CARWN] 2015/09/21 20:22:13.423603 set.go:93: DEBUG: Projekte Update(SXH6KAV-GARHFRL-WQ45IPL-KUA6LMZ-ZFAPW5Z-A322H4B-7TV5ISK-XLHHSQP, [1000])
[CARWN] 2015/09/21 20:22:14.132343 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 1950185 true
[CARWN] 2015/09/21 20:22:14.132982 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:22:15.816562 model.go:533: DEBUG: model@0x11d4df40 IDXUP(in): SXH6KAV-GARHFRL-WQ45IPL-KUA6LMZ-ZFAPW5Z-A322H4B-7TV5ISK-XLHHSQP / "Projekte": 1000 files
[CARWN] 2015/09/21 20:22:15.822882 set.go:93: DEBUG: Projekte Update(SXH6KAV-GARHFRL-WQ45IPL-KUA6LMZ-ZFAPW5Z-A322H4B-7TV5ISK-XLHHSQP, [1000])
[CARWN] 2015/09/21 20:22:18.146679 model.go:533: DEBUG: model@0x11d4df40 IDXUP(in): SXH6KAV-GARHFRL-WQ45IPL-KUA6LMZ-ZFAPW5Z-A322H4B-7TV5ISK-XLHHSQP / "Projekte": 1000 files
[CARWN] 2015/09/21 20:22:18.153156 set.go:93: DEBUG: Projekte Update(SXH6KAV-GARHFRL-WQ45IPL-KUA6LMZ-ZFAPW5Z-A322H4B-7TV5ISK-XLHHSQP, [1000])
[CARWN] 2015/09/21 20:22:20.669678 model.go:533: DEBUG: model@0x11d4df40 IDXUP(in): SXH6KAV-GARHFRL-WQ45IPL-KUA6LMZ-ZFAPW5Z-A322H4B-7TV5ISK-XLHHSQP / "Projekte": 1000 files
[CARWN] 2015/09/21 20:22:20.672532 set.go:93: DEBUG: Projekte Update(SXH6KAV-GARHFRL-WQ45IPL-KUA6LMZ-ZFAPW5Z-A322H4B-7TV5ISK-XLHHSQP, [1000])
[CARWN] 2015/09/21 20:22:23.236968 model.go:533: DEBUG: model@0x11d4df40 IDXUP(in): SXH6KAV-GARHFRL-WQ45IPL-KUA6LMZ-ZFAPW5Z-A322H4B-7TV5ISK-XLHHSQP / "Projekte": 1000 files
[CARWN] 2015/09/21 20:22:23.242979 set.go:93: DEBUG: Projekte Update(SXH6KAV-GARHFRL-WQ45IPL-KUA6LMZ-ZFAPW5Z-A322H4B-7TV5ISK-XLHHSQP, [1000])
[CARWN] 2015/09/21 20:22:24.228833 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 1950185 true
[CARWN] 2015/09/21 20:22:24.229404 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:22:25.867339 model.go:533: DEBUG: model@0x11d4df40 IDXUP(in): SXH6KAV-GARHFRL-WQ45IPL-KUA6LMZ-ZFAPW5Z-A322H4B-7TV5ISK-XLHHSQP / "Projekte": 1000 files
[CARWN] 2015/09/21 20:22:25.870104 set.go:93: DEBUG: Projekte Update(SXH6KAV-GARHFRL-WQ45IPL-KUA6LMZ-ZFAPW5Z-A322H4B-7TV5ISK-XLHHSQP, [1000])
[CARWN] 2015/09/21 20:22:28.109860 model.go:533: DEBUG: model@0x11d4df40 IDXUP(in): SXH6KAV-GARHFRL-WQ45IPL-KUA6LMZ-ZFAPW5Z-A322H4B-7TV5ISK-XLHHSQP / "Projekte": 1000 files
[CARWN] 2015/09/21 20:22:28.115680 set.go:93: DEBUG: Projekte Update(SXH6KAV-GARHFRL-WQ45IPL-KUA6LMZ-ZFAPW5Z-A322H4B-7TV5ISK-XLHHSQP, [1000])
[CARWN] 2015/09/21 20:22:31.278212 model.go:533: DEBUG: model@0x11d4df40 IDXUP(in): SXH6KAV-GARHFRL-WQ45IPL-KUA6LMZ-ZFAPW5Z-A322H4B-7TV5ISK-XLHHSQP / "Projekte": 1000 files
[CARWN] 2015/09/21 20:22:31.280994 set.go:93: DEBUG: Projekte Update(SXH6KAV-GARHFRL-WQ45IPL-KUA6LMZ-ZFAPW5Z-A322H4B-7TV5ISK-XLHHSQP, [1000])
[CARWN] 2015/09/21 20:22:33.641751 model.go:533: DEBUG: model@0x11d4df40 IDXUP(in): SXH6KAV-GARHFRL-WQ45IPL-KUA6LMZ-ZFAPW5Z-A322H4B-7TV5ISK-XLHHSQP / "Projekte": 1000 files
[CARWN] 2015/09/21 20:22:33.647698 set.go:93: DEBUG: Projekte Update(SXH6KAV-GARHFRL-WQ45IPL-KUA6LMZ-ZFAPW5Z-A322H4B-7TV5ISK-XLHHSQP, [1000])
[CARWN] 2015/09/21 20:22:34.243118 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 1950185 true
[CARWN] 2015/09/21 20:22:34.243659 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:22:35.848768 model.go:533: DEBUG: model@0x11d4df40 IDXUP(in): SXH6KAV-GARHFRL-WQ45IPL-KUA6LMZ-ZFAPW5Z-A322H4B-7TV5ISK-XLHHSQP / "Projekte": 1000 files
[CARWN] 2015/09/21 20:22:35.851497 set.go:93: DEBUG: Projekte Update(SXH6KAV-GARHFRL-WQ45IPL-KUA6LMZ-ZFAPW5Z-A322H4B-7TV5ISK-XLHHSQP, [1000])
[CARWN] 2015/09/21 20:22:38.426950 model.go:533: DEBUG: model@0x11d4df40 IDXUP(in): SXH6KAV-GARHFRL-WQ45IPL-KUA6LMZ-ZFAPW5Z-A322H4B-7TV5ISK-XLHHSQP / "Projekte": 1000 files
[CARWN] 2015/09/21 20:22:38.429698 set.go:93: DEBUG: Projekte Update(SXH6KAV-GARHFRL-WQ45IPL-KUA6LMZ-ZFAPW5Z-A322H4B-7TV5ISK-XLHHSQP, [1000])
[CARWN] 2015/09/21 20:22:40.271151 model.go:533: DEBUG: model@0x11d4df40 IDXUP(in): SXH6KAV-GARHFRL-WQ45IPL-KUA6LMZ-ZFAPW5Z-A322H4B-7TV5ISK-XLHHSQP / "Projekte": 1000 files
[CARWN] 2015/09/21 20:22:40.286167 set.go:93: DEBUG: Projekte Update(SXH6KAV-GARHFRL-WQ45IPL-KUA6LMZ-ZFAPW5Z-A322H4B-7TV5ISK-XLHHSQP, [1000])
[CARWN] 2015/09/21 20:22:42.768748 model.go:533: DEBUG: model@0x11d4df40 IDXUP(in): SXH6KAV-GARHFRL-WQ45IPL-KUA6LMZ-ZFAPW5Z-A322H4B-7TV5ISK-XLHHSQP / "Projekte": 1000 files
[CARWN] 2015/09/21 20:22:42.794463 set.go:93: DEBUG: Projekte Update(SXH6KAV-GARHFRL-WQ45IPL-KUA6LMZ-ZFAPW5Z-A322H4B-7TV5ISK-XLHHSQP, [1000])
Afterwards it continues with
[CARWN] 2015/09/21 20:27:47.424526 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:27:48.464118 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:27:57.501058 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:27:58.520705 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:28:07.693296 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:28:08.557195 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:28:17.724098 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:28:18.623513 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:28:27.740707 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:28:28.640163 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:28:37.777499 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:28:38.666479 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:28:47.830680 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:28:48.697424 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:28:57.874606 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:28:58.739468 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:29:07.926216 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:29:08.815770 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:29:18.002731 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:29:18.838970 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:29:28.049343 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:29:28.918910 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:29:38.157273 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:29:38.966425 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:29:48.212182 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:29:49.021843 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:29:58.233019 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:29:59.098200 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:30:08.265122 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:30:09.138388 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:30:18.321422 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:30:19.176644 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:30:28.427773 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:30:29.222422 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:30:38.454570 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:30:39.273999 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:30:48.500820 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:30:49.340474 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:30:58.597262 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:30:59.373379 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:31:08.703816 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:31:09.415178 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:31:18.790168 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:31:19.436128 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:31:28.815936 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:31:29.536385 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:31:38.861066 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:31:39.632850 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:31:48.874652 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:31:49.659773 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:31:58.936177 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:31:59.667270 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:32:09.022576 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:32:09.710533 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:32:19.049738 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:32:19.778958 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:32:29.065760 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:32:29.835250 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:32:39.131975 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:32:39.859703 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
[CARWN] 2015/09/21 20:32:49.195730 rwfolder.go:196: DEBUG: rwFolder/Z3C_Bilder@0x11f04140 skip (curVer == prevVer) 365339 true
[CARWN] 2015/09/21 20:32:49.938074 rwfolder.go:196: DEBUG: rwFolder/Bilder@0x129b1720 skip (curVer == prevVer) 0 true
The first one it’s just receiving updates about files from others, the second one it’s just sitting idle.
system
(system)
closed
October 21, 2015, 11:36pm
#5
