I have SyncTrayzor on my Windows computer and Syncthing Fork on two Android phones. They will get synced only locally via WiFi.
Today I tested SyncthingTray while SyncTrayzor was running. Perhaps that was not a good idea. I don’t use SyncthingTray any more and the next time I connected the three devices via SyncTrayzor and Syncthing Fork the computer, while being connected already, began to ask for connecting to the phones a second time with a different ID but same name and same folders. I rejected and after a short while it asked again with another ID.
What does that mean? What went wrong and how can I fix that?
I noticed two syncthing.exe processes in the Windows Task Manger with the same command line. Is that normal?
Thank you for your willingness to help and sorry for my late response. I didn’t get a notification about your answer.
Eventually I uninstalled SyncTrayzor and Syncthing and removed all remnants I found in file system and registry, checked the config.xml and deleted the database, then reinstalled with the backed up syncthing settings. After several reboots and whatever attempts I don’t remember any more the problem seems to be fixed.
