I’ve extended the build setup to build for all OS/architecture combinations supported by the toolchain, minus those Syncthing doesn’t actually build on for whatever reason. This includes the the Relay and Discovery servers, for which I’ve made new releases:
- https://github.com/syncthing/discosrv/releases/tag/v0.14.48
- https://github.com/syncthing/relaysrv/releases/tag/v0.14.48
For Syncthing the new architectures (which are fewer) will be in the next main release. The set of architectures supported for Syncthing, the Relay Server and the Discovery Server is now:
dragonfly/amd64
(new for Relay & Discovery servers) -
freebsd/386
(new for Relay & Discovery servers) freebsd/amd64
freebsd/arm
(new for Relay & Discovery servers) linux/386
linux/amd64
linux/arm
linux/arm64
linux/mips
linux/mipsle
linux/mips64
(new for Syncthing, Relay & Discovery servers) -
linux/mips64le
linux/ppc64
linux/ppc64le
linux/s390x
macos/386
macos/amd64
netbsd/386
netbsd/amd64
openbsd/386
(new for Relay & Discovery servers) openbsd/amd64
openbsd/arm
(new for Syncthing, Relay & Discovery servers) solaris/amd64
windows/386
(new for Relay & Discovery servers) windows/amd64
Architectures we support but do not generate packages for:
android/arm
android/arm64
android/386
(These are packaged in the app.)
Architectures that could theoretically be supported but currently are not:
darwin/arm
(i.e., iOS - unclear to what extent this build target is useful) -
nacl/*
(too constrained) -
netbsd/arm
(build failure) -
plan9/*
(build failure)
The latter two could probably be fixed if someone had the inclination to do so.
