Hello, my weakest point of the network (local) is 1200mbps, which at a maximum should translate to 150 MB/s.
Instead I am receiving 3.3MB/s at most.
I have unchecked the enable relaying tick box as was suggested in a 2014 support thread. Searching for “maximum speed” did not provide many useful results.
I have seen users describe speeds in excess of 90MB/s so I know it is possible.
Can someone explain what I am doing wrong? I have set the IP address as tcp://192.xxx.x.xxx:22000 for each of my computers. And disabled relaying. I do not know if there are further settings I should modify. CPU utilization on both these machines stays under 10%. One is a desktop the other a laptop. Any help appreciated. Thank you very much for the program!
I did see someone make note that many super small files would result in roughly 4 MB/s and giant file transfers would be much higher speeds. I am using lots of medium files which I read should be a happy medium. Files between 4MB to 50MB at most. I am assuming by tiny he meant 128kb .txt files. Mostly my powerpoints and audio library. And the powerpoints are 50MB since they have audio embedded.
Again, thanks!
