first <-LAN-> second
second <-Internet->third
first <-Internet->third
first:
янв 24 20:57:26 srv syncthing[43665]: [CBTQB] INFO: Puller: final: peers who had this file went away, or the file has changed while syncing. will retry later
янв 24 20:57:26 srv syncthing[43665]: [CBTQB] INFO: Puller (folder "gopath", file "src/github.com/hdhog/starter/node_modules/fbjs/lib/forEachObject.js"): pull:
янв 24 20:57:26 srv syncthing[43665]: [CBTQB] INFO: Puller (folder "gopath", file "src/github.com/hdhog/starter/node_modules/coa/lib/completion.sh"): pull: pee
янв 24 20:57:26 srv syncthing[43665]: [CBTQB] INFO: Puller (folder "gopath", file "src/github.com/hdhog/starter/node_modules/babel-eslint/node_modules/lodash/i
янв 24 20:57:26 srv syncthing[43665]: [CBTQB] INFO: Puller (folder "gopath", file "src/github.com/hdhog/starter/node_modules/babel-plugin-transform-export-exte
янв 24 20:57:26 srv syncthing[43665]: [CBTQB] INFO: Puller (folder "gopath", file "src/github.com/hdhog/starter/node_modules/babel-plugin-proto-to-assign/node_
янв 24 20:57:26 srv syncthing[43665]: [CBTQB] INFO: Puller (folder "gopath", file "src/github.com/hdhog/starter/node_modules/babel-eslint/node_modules/lodash/a
янв 24 20:57:26 srv syncthing[43665]: [CBTQB] INFO: Puller (folder "gopath", file "src/github.com/hdhog/starter/node_modules/defs/build/es5/stats.js"): pull: p
янв 24 20:57:26 srv syncthing[43665]: [CBTQB] INFO: Puller (folder "gopath", file "src/github.com/hdhog/starter/node_modules/expose-loader/README.md"): pull: p
янв 24 20:57:46 srv syncthing[43665]: [CBTQB] INFO: Established secure connection to C6CCU2O-TNGEROP-WAYVDOT-YSPCNDV-KT6EERO-2ZEKCME-RPQD3PD-4LJT6AZ at 172.16.
янв 24 20:57:46 srv syncthing[43665]: [CBTQB] INFO: Device C6CCU2O-TNGEROP-WAYVDOT-YSPCNDV-KT6EERO-2ZEKCME-RPQD3PD-4LJT6AZ client is "syncthing v0.14.20" named
янв 24 20:57:46 srv syncthing[43665]: [CBTQB] INFO: Connection to C6CCU2O-TNGEROP-WAYVDOT-YSPCNDV-KT6EERO-2ZEKCME-RPQD3PD-4LJT6AZ closed: reading length: read
янв 24 20:57:47 srv syncthing[43665]: [CBTQB] INFO: Established secure connection to YOSTSGD-B5G6VRN-FXPOXFZ-WSPNOLW-OWDRPXA-YLQTDYT-KBQSRYI-WOP6HQA at 172.16.
янв 24 20:57:47 srv syncthing[43665]: [CBTQB] INFO: Device YOSTSGD-B5G6VRN-FXPOXFZ-WSPNOLW-OWDRPXA-YLQTDYT-KBQSRYI-WOP6HQA client is "syncthing v0.14.19" named
янв 24 20:57:47 srv syncthing[43665]: [CBTQB] INFO: Connection to YOSTSGD-B5G6VRN-FXPOXFZ-WSPNOLW-OWDRPXA-YLQTDYT-KBQSRYI-WOP6HQA closed: writing message: writ
lines 61775-61800/61800 (END)
second
[C6CCU] 20:57:23 INFO: Established secure connection to CBTQB2S-7EP5ELP-GRRXF6B-CQAX6AM-BNLQTW5-ETDP4Z2-ZHLQXZA-SFMSLAZ at [fe80::8ea9:82ff:fe3a:8254%wlan0]:22000-[fe80::9618:82ff:fe37:b521%wlan0]:38912 (tcp-server) (TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384)
[C6CCU] 20:57:23 INFO: Device CBTQB2S-7EP5ELP-GRRXF6B-CQAX6AM-BNLQTW5-ETDP4Z2-ZHLQXZA-SFMSLAZ client is "syncthing v0.14.20" named "srv"
[C6CCU] 20:57:46 INFO: Connected to already connected device (CBTQB2S-7EP5ELP-GRRXF6B-CQAX6AM-BNLQTW5-ETDP4Z2-ZHLQXZA-SFMSLAZ)
[C6CCU] 20:57:48 INFO: Puller (folder "rn", file "miui_HM4ProGlobal_V8.1.2.0.MBEMIDI_a8edfe4ee7_6.0.zip"): pull: peers who had this file went away, or the file has changed while syncing. will retry later
[C6CCU] 20:57:48 INFO: Connection to CBTQB2S-7EP5ELP-GRRXF6B-CQAX6AM-BNLQTW5-ETDP4Z2-ZHLQXZA-SFMSLAZ closed: writing message: write tcp [fe80::8ea9:82ff:fe3a:8254%wlan0]:22000->[fe80::9618:82ff:fe37:b521%wlan0]:38912: write: connection reset by peer
[C6CCU] 20:57:48 INFO: Puller: final: peers who had this file went away, or the file has changed while syncing. will retry later
[C6CCU] 20:58:24 INFO: Established secure connection to CBTQB2S-7EP5ELP-GRRXF6B-CQAX6AM-BNLQTW5-ETDP4Z2-ZHLQXZA-SFMSLAZ at [fe80::8ea9:82ff:fe3a:8254%wlan0]:22000-[fe80::9618:82ff:fe37:b521%wlan0]:39178 (tcp-server) (TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384)
[C6CCU] 20:58:24 INFO: Device CBTQB2S-7EP5ELP-GRRXF6B-CQAX6AM-BNLQTW5-ETDP4Z2-ZHLQXZA-SFMSLAZ client is "syncthing v0.14.20" named "srv"
[C6CCU] 20:58:49 INFO: Connected to already connected device (CBTQB2S-7EP5ELP-GRRXF6B-CQAX6AM-BNLQTW5-ETDP4Z2-ZHLQXZA-SFMSLAZ)
[C6CCU] 20:58:49 INFO: Puller (folder "rn", file "miui_HM4ProGlobal_V8.1.2.0.MBEMIDI_a8edfe4ee7_6.0.zip"): pull: peers who had this file went away, or the file has changed while syncing. will retry later
[C6CCU] 20:58:49 INFO: Connection to CBTQB2S-7EP5ELP-GRRXF6B-CQAX6AM-BNLQTW5-ETDP4Z2-ZHLQXZA-SFMSLAZ closed: writing message: write tcp [fe80::8ea9:82ff:fe3a:8254%wlan0]:22000->[fe80::9618:82ff:fe37:b521%wlan0]:39178: write: connection reset by peer
[C6CCU] 20:58:49 INFO: Puller: final: peers who had this file went away, or the file has changed while syncing. will retry later
third
[XY2XC] 20:55:09 INFO: Puller (folder "gopath", file "src/github.com/hdhog/starter/node_modules/dom-walk/example/static/bundle.js"): pull: peers who had this file went away, or the file has changed while syncing. will retry later
[XY2XC] 20:55:09 INFO: Puller: final: peers who had this file went away, or the file has changed while syncing. will retry later
[XY2XC] 20:55:09 INFO: Puller (folder "gopath", file "src/github.com/hdhog/starter/node_modules/slash/package.json"): pull: peers who had this file went away, or the file has changed while syncing. will retry later
[XY2XC] 20:55:09 INFO: Puller (folder "gopath", file "src/github.com/hdhog/starter/node_modules/postcss-custom-media/LICENSE"): pull: peers who had this file went away, or the file has changed while syncing. will retry later
[XY2XC] 20:55:09 INFO: Puller (folder "gopath", file "src/github.com/hdhog/starter/node_modules/caniuse-db/region-usage-json/VU.json"): pull: peers who had this file went away, or the file has changed while syncing. will retry later
[XY2XC] 20:55:09 INFO: Puller (folder "gopath", file "src/github.com/hdhog/starter/node_modules/babel-eslint/node_modules/lodash/lang/isRegExp.js"): pull: peers who had this file went away, or the file has changed while syncing. will retry later
[XY2XC] 20:55:09 INFO: Puller (folder "gopath", file "src/github.com/hdhog/starter/node_modules/postcss-ordered-values/dist/lib/getValue.js"): pull: peers who had this file went away, or the file has changed while syncing. will retry later
[XY2XC] 20:55:09 INFO: Puller (folder "gopath", file "src/github.com/hdhog/starter/node_modules/source-list-map/lib/MappingsContext.js"): pull: peers who had this file went away, or the file has changed while syncing. will retry later
[XY2XC] 20:57:01 INFO: Connected to already connected device (CBTQB2S-7EP5ELP-GRRXF6B-CQAX6AM-BNLQTW5-ETDP4Z2-ZHLQXZA-SFMSLAZ)
[XY2XC] 20:58:56 INFO: Connected to already connected device (CBTQB2S-7EP5ELP-GRRXF6B-CQAX6AM-BNLQTW5-ETDP4Z2-ZHLQXZA-SFMSLAZ)
