logseq copy in Emacs
of course separating the database of notes/blocks and read/un-read states by device was thought specially after Syncthing usage between my Android running Emacs in Termux and my desktop!
I have zero idea what’s you’re trying to communicate. Perhaps you should have an introduction or something.
Maybe explain a little what the problem is, what devices you’re using, and where syncthing comes in the picture.
no problem at all… was just showing off on “User Stories” what i made in Emacs! it followed a pattern to avoid conflicting files, which was made after Syncthing, as i use it with my Android and my desktop
