I came across this post: Minimum amount of log file handling we can possibly get away with?.
Is this because output redirection is more efficient than doing I/O from Go? Are you all redirecting outputs to a different program? I would assume that if you’re redirecting output to a file it would be the same (and or worse)? I am a new developer so forgive the potentially dumb question.
Thanks, just curious. DAlba-sudo
