Local Syncs between two truenas servers
Hello,
I am not sure what I am doing wrong, but I cannot get two local truenas servers to find each other. I turned off WAN Relay and some other options and I tried different ports, for the love of god I cant get these to connect.
Servers have different IPs and initially had the same ports…not sure if that matters but I reinstalled the docker container with different ports and I still cant get these to find each other.
does anyone have advice on setting up sync thing locally? I can get them to connect when WAN relay is on but im trying to sync 150tb of linux ISO’s and it was taking too long. I am not the best with networking/ports so I might be falling on my face there…
Thanks in advance
Welcome here @M3NACE !
Did you happen to turn off global discovery? Despite its name, it also help devices in local networks in some difficult situations.
Others using TrueNAS also benefit from enabling “Host network”.
Hope this helps!
I did not try the host networking, I reinstalled the containers and almost enabled it, I did turn off global discovery because of some of the other “guides” I found online
Well… Do try them.
