First time setting up Syncthing, so I’m not really familiar with everything yet. Having an issue with Discovery port binding I’m not sure how to understand.
I’ve got two (eventually more) Windows 10 systems each running two (eventually more) instances. Each instance is started as a different user on system startup. Each has its own GUI Listen port, and each has Sync Protocol Listen Addresses of the form tcp://0.0.0.0:22008, quic://0.0.0.0:22008 where the ports are different for each instance. NAT traversal, Global Discovery, and Relaying, are all turned off, but Local Discovery is on. The idea is that I want to connect only to specific hosts that I control, without relying on external services at all.
Here’s the thing I’m seeing that I’m not sure how to understand: on one of my hosts, under “This Device”, I typically see a red “0/2” listed in the “Discovery” line, where clicking on it gives me the following:
- IPv4 local: listen udp4 :21027: bind: Only one usage of each socket address (protocol/network address/port) is normally permitted.
- IPv6 local: listen udp6 [ff12::8384]:21027: bind: An attempt was made to access a socket in a way forbidden by its access permissions.
The other instance on the same host has no trouble and shows 2/2 for Discovery.
How do I interpret what I’m seeing here? How do I prevent port conflicts from multiple instances running side-by-side?
Making things weirder, occasionally, I can get a 2/2 on one instance and a 1/2 on the other (that is, conflict trying to grab the UDP port on the IPv4 address but on the IPv6 address working okay), but it is inconsistent. Sometimes it works, and sometimes it doesn’t.
When I see it working, looking at the Windows Resource Monitor shows the port (21027) in use alternately by two different processes. When it isn’t working, that port just seems to be held forever by just one of the processes.
Any ideas as to what I should be looking for or how to understand the issue here?
Thanks.
