Hi, which is the bes way to config the listeners and set the global/local anouncement ?
I have 5 offices with at least one server on each office. They are connected via 300mbps with VPN between them.
In the main office I have 2 servers, and for an undetermined time 2 more servers for replacing old servers.
Al offices can perform changes at the shared folder.
I supose that local announcement only works in the LAN. How did works the Global announcement?
I have servers with 3/3 listeners, others with 2/2. And servers with 4/5 discovery, and others with 2/5.
Which is the most reliable config setup?
I have disabled introducer option in all servers unless in one server. I add the servers with a fixed IP.
The relay option uses external servers? or is an option to relay the files between the sync group? If I enable the allow relay could be slowing the sync?
