I am new to Syncthing.
My problem is, that the Web GUI shows a max upload of 1.25 Mbytes.
I tried uploading different file sizes and I always have a max of 1.25 Mbytes.
My normal upload is 11 Mbytes.
I am syncing to an other PC over the Internet.
I am running Win 7 64bit
Things I have checked:
No upload/download limits set
CPU load = about 1%
RAM usage = 60MB
My provider upload rate = 11 Mbytes
Download rate of the receaving PC = 10 Mbytes
I am just wondering why I cant get a higher upload, even though my pc is almost at IDLE.
I opened the ports TCP 22000 and UDP 21027 and now the PCs are instantly connected. The “Ralayed via” changed to “Address” BUT now it is even slower. 720KiB/s
Edit: Going to sleep now. It´s 00:10 here in Austria.
Thanks for the fast replies. We gonna fix that
I also tried it with a single file (about 12GB) but there is no difference.
I am not home till monday but the ping must be about 50ms.
I read a lot on the forum and the strange is, that most people say that syncthing is using to much system power. But for me, it was never over 5% CPU load an 150MB RAM.
Just to make sure there is no confusion here, you mention your line rates as “10 MBytes” (per second, presumably) which is 80 Mbps and “11 MBytes” which is 88 Mbps. Your max transfer rate is 1.25 MBytes/s which equals 10 Mbps. Are you sure you are not in fact on a 10 Mbps connection?
You can try increasing the number of pullers in advanced folder config to something like 300, and see if that makes any difference. Also, make sure bandwidth limits are not enabled on either side.
Back again. I tired to sync to an other PC. Same thing. I just get around 1.5 Mbytes/s and my PC is at 1% usage…
I opened all ports, connected directly, inceased pullers and pusher. But nothing helped.
I also tried using an other program and there was no problem sending the data. Got about 11 Mbytes/s. But I really want to securely transmit data. And syncthing is the best way.
