I’ve been getting repeated errors on one of my syncthing nodes. Note that this might be due to mistakes on my end. This node accidentally had bysync still running when I initially installed syncthing on it. There was some sort of conflict that caused panics on syncthing. I uninstalled both syncthing and btsync and reinstalled syncthing.
Syncthing appears to be working properly now but I’m getting occasional leveldb errors like the following. I usually get approximately 5-10 of these on startup and they sporadically pop up a few times a day as syncthing is running. The files listed in the errors seem to be random and don’t seem to repeat. Is this something that I should be concerned about?
[DQU5S] 17:15:29 DEBUG: folder: “Music” (4d75736963) [DQU5S] 17:15:29 DEBUG: key: “\x01Music\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00Hank Green/I’m So Bad at This_ Live!/Hank Green (I’m So Bad at This_ Live!) - 20 - Not Edward.flac” (014d75736963000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000048616e6b20477265656e2f49276d20536f2042616420617420546869735f204c697665212f48616e6b20477265656e202849276d20536f2042616420617420546869735f204c6976652129202d203230202d204e6f74204564776172642e666c6163) [DQU5S] 17:15:29 DEBUG: vl: {{486065, M2RETH3-2MIWVQI-Q2B6YU2-VUOMJN4-O55DXL4-UERPG5D-AKXD755-HGOWQAR}, {486065, 7777777-777777N-7777777-777777N-7777777-777777N-7777777-77777Q4}} [DQU5S] 17:15:29 DEBUG: vl.versions[0].device: 66a2499f7a622d584341f629aad1cc4b5dde8eebe509179ba055c7fef4e675a0 [DQU5S] 17:15:29 DEBUG: name: “Hank Green/I’m So Bad at This_ Live!/Hank Green (I’m So Bad at This_ Live!) - 20 - Not Edward.flac” (48616e6b20477265656e2f49276d20536f2042616420617420546869735f204c697665212f48616e6b20477265656e202849276d20536f2042616420617420546869735f204c6976652129202d203230202d204e6f74204564776172642e666c6163) [DQU5S] 17:15:29 DEBUG: fk: “\x00Music\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00f\xa2I\x9fzb-XCA\xf6)\xaa\xd1\xccK]ގ\xeb\xe5\t\x17\x9b\xa0U\xc7\xfe\xf4\xe6u\xa0Hank Green/I’m So Bad at This_ Live!/Hank Green (I’m So Bad at This_ Live!) - 20 - Not Edward.flac” [DQU5S] 17:15:29 DEBUG: fk: 4d757369630000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 66a2499f7a622d584341f629aad1cc4b5dde8eebe509179ba055c7fef4e675a0 48616e6b20477265656e2f49276d20536f2042616420617420546869735f204c697665212f48616e6b20477265656e202849276d20536f2042616420617420546869735f204c6976652129202d203230202d204e6f74204564776172642e666c6163 [DQU5S] 17:15:29 INFO: recovered: leveldb: not found [DQU5S] 17:15:30 DEBUG: folder: “Music” (4d75736963) [DQU5S] 17:15:30 DEBUG: key: “\x01Music\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00Hank Green/I’m So Bad at This_ Live!/Hank Green (I’m So Bad at This_ Live!) - 20 - Not Edward.flac” (014d75736963000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000048616e6b20477265656e2f49276d20536f2042616420617420546869735f204c697665212f48616e6b20477265656e202849276d20536f2042616420617420546869735f204c6976652129202d203230202d204e6f74204564776172642e666c6163) [DQU5S] 17:15:30 DEBUG: vl: {{486065, M2RETH3-2MIWVQI-Q2B6YU2-VUOMJN4-O55DXL4-UERPG5D-AKXD755-HGOWQAR}, {486065, 7777777-777777N-7777777-777777N-7777777-777777N-7777777-77777Q4}} [DQU5S] 17:15:30 DEBUG: vl.versions[0].device: 66a2499f7a622d584341f629aad1cc4b5dde8eebe509179ba055c7fef4e675a0 [DQU5S] 17:15:30 DEBUG: name: “Hank Green/I’m So Bad at This_ Live!/Hank Green (I’m So Bad at This_ Live!) - 20 - Not Edward.flac” (48616e6b20477265656e2f49276d20536f2042616420617420546869735f204c697665212f48616e6b20477265656e202849276d20536f2042616420617420546869735f204c6976652129202d203230202d204e6f74204564776172642e666c6163) [DQU5S] 17:15:30 DEBUG: fk: “\x00Music\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00f\xa2I\x9fzb-XCA\xf6)\xaa\xd1\xccK]ގ\xeb\xe5\t\x17\x9b\xa0U\xc7\xfe\xf4\xe6u\xa0Hank Green/I’m So Bad at This_ Live!/Hank Green (I’m So Bad at This_ Live!) - 20 - Not Edward.flac” [DQU5S] 17:15:30 DEBUG: fk: 4d757369630000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 66a2499f7a622d584341f629aad1cc4b5dde8eebe509179ba055c7fef4e675a0 48616e6b20477265656e2f49276d20536f2042616420617420546869735f204c697665212f48616e6b20477265656e202849276d20536f2042616420617420546869735f204c6976652129202d203230202d204e6f74204564776172642e666c6163 [DQU5S] 17:15:30 INFO: recovered: leveldb: not found [DQU5S] 17:15:30 DEBUG: folder: “Music” (4d75736963) [DQU5S] 17:15:30 DEBUG: key: “\x01Music\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00Hank Green/I’m So Bad at This_ Live!/Hank Green (I’m So Bad at This_ Live!) - 20 - Not Edward.flac” (014d75736963000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000048616e6b20477265656e2f49276d20536f2042616420617420546869735f204c697665212f48616e6b20477265656e202849276d20536f2042616420617420546869735f204c6976652129202d203230202d204e6f74204564776172642e666c6163) [DQU5S] 17:15:30 DEBUG: vl: {{486065, M2RETH3-2MIWVQI-Q2B6YU2-VUOMJN4-O55DXL4-UERPG5D-AKXD755-HGOWQAR}, {486065, 7777777-777777N-7777777-777777N-7777777-777777N-7777777-77777Q4}} [DQU5S] 17:15:30 DEBUG: vl.versions[0].device: 66a2499f7a622d584341f629aad1cc4b5dde8eebe509179ba055c7fef4e675a0 [DQU5S] 17:15:30 DEBUG: name: “Hank Green/I’m So Bad at This_ Live!/Hank Green (I’m So Bad at This_ Live!) - 20 - Not Edward.flac” (48616e6b20477265656e2f49276d20536f2042616420617420546869735f204c697665212f48616e6b20477265656e202849276d20536f2042616420617420546869735f204c6976652129202d203230202d204e6f74204564776172642e666c6163) [DQU5S] 17:15:30 DEBUG: fk: “\x00Music\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00f\xa2I\x9fzb-XCA\xf6)\xaa\xd1\xccK]ގ\xeb\xe5\t\x17\x9b\xa0U\xc7\xfe\xf4\xe6u\xa0Hank Green/I’m So Bad at This_ Live!/Hank Green (I’m So Bad at This_ Live!) - 20 - Not Edward.flac” [DQU5S] 17:15:30 DEBUG: fk: 4d757369630000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 66a2499f7a622d584341f629aad1cc4b5dde8eebe509179ba055c7fef4e675a0 48616e6b20477265656e2f49276d20536f2042616420617420546869735f204c697665212f48616e6b20477265656e202849276d20536f2042616420617420546869735f204c6976652129202d203230202d204e6f74204564776172642e666c6163 [DQU5S] 17:15:30 INFO: recovered: leveldb: not found [DQU5S] 17:15:31 DEBUG: folder: “Music” (4d75736963) [DQU5S] 17:15:31 DEBUG: key: “\x01Music\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00Hank Green/I’m So Bad at This_ Live!/Hank Green (I’m So Bad at This_ Live!) - 20 - Not Edward.flac” (014d75736963000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000048616e6b20477265656e2f49276d20536f2042616420617420546869735f204c697665212f48616e6b20477265656e202849276d20536f2042616420617420546869735f204c6976652129202d203230202d204e6f74204564776172642e666c6163) [DQU5S] 17:15:31 DEBUG: vl: {{486065, M2RETH3-2MIWVQI-Q2B6YU2-VUOMJN4-O55DXL4-UERPG5D-AKXD755-HGOWQAR}, {486065, 7777777-777777N-7777777-777777N-7777777-777777N-7777777-77777Q4}} [DQU5S] 17:15:31 DEBUG: vl.versions[0].device: 66a2499f7a622d584341f629aad1cc4b5dde8eebe509179ba055c7fef4e675a0 [DQU5S] 17:15:31 DEBUG: name: “Hank Green/I’m So Bad at This_ Live!/Hank Green (I’m So Bad at This_ Live!) - 20 - Not Edward.flac” (48616e6b20477265656e2f49276d20536f2042616420617420546869735f204c697665212f48616e6b20477265656e202849276d20536f2042616420617420546869735f204c6976652129202d203230202d204e6f74204564776172642e666c6163) [DQU5S] 17:15:31 DEBUG: fk: “\x00Music\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00f\xa2I\x9fzb-XCA\xf6)\xaa\xd1\xccK]ގ\xeb\xe5\t\x17\x9b\xa0U\xc7\xfe\xf4\xe6u\xa0Hank Green/I’m So Bad at This_ Live!/Hank Green (I’m So Bad at This_ Live!) - 20 - Not Edward.flac” [DQU5S] 17:15:31 DEBUG: fk: 4d757369630000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 66a2499f7a622d584341f629aad1cc4b5dde8eebe509179ba055c7fef4e675a0 48616e6b20477265656e2f49276d20536f2042616420617420546869735f204c697665212f48616e6b20477265656e202849276d20536f2042616420617420546869735f204c6976652129202d203230202d204e6f74204564776172642e666c6163 [DQU5S] 17:15:31 INFO: recovered: leveldb: not found
