I want to synchronize apache config files
so after synchro is done I want to automaticaly do a sudo apache2ctl restart
is it possible ?
thanks
is it possible ?
thanks
Currently, no. You’ll need to monitor the REST interface for events and react to those.
Or, since I guess apache won’t be changing it’s config by itself, use a unidirectional sync program like rsync or an actual deployment script of some sort.
ok
