Hello On my Nas (ARM) syncthing make a lot of files (over 475000) under index-v0.14.0.db while large is parameter
You should set it to small unconditionally on 32bit systems.
Or to auto, which defaults to small on 32bit.
Thant you for reply Does i re start with -reset -database?
You can do that, but in theory it should just fix itself over time.
Thank you for the reply
