Hello, Syncthing has been running great for me, and I would like to set up a private relay.
To show that I have put forth some effort before posting, I have attempted to get this going over four weekends and many nights after work to no avail. During that time I have read 20-30+ articles and forum posts and made 100’s of AI chatbot searches for help.
Since I just want to get anything working, I tried to keep the setup as simple as possible.
Setups attempted:
- (LAN) Proxmox - Alpine Container - Latest Github version: v1.22.1
- (LAN) Proxmox - Debian Container - Latest Debian syncthing-relaysrv version: v1.19.2 (does not work since tokens were not implemented in this version)
- (LAN) Proxmox - Alpine Container - Latest Docker syncthing/relaysrv version: v1.27.7
- (WAN) DreamHost DreamCompute - Alpine Instance - Latest Github version: v1.22.1
- (WAN) DreamHost DreamCompute - Alpine Instance - Latest Docker syncthing/relaysrv version: v1.27.7
- (WAN) DreamHost DreamCompute - Debian Instance - Latest Docker syncthing/relaysrv version: v1.27.7
- (LAN) Raspberry Pi 5 - Raspberry Pi OS - Latest Github ARM64 version: v1.22.1
For (LAN) setups, I will use the following IDs and IP addresses:
- Relay: 192.168.1.1 - RELAY-RELAY-RELAY-RELAY-RELAY-RELAY-RELAY-RELAY
- Computer: 192.168.1.2 - COMP-COMP-COMP-COMP-COMP-COMP-COMP-COMP
- Phone: 192.168.1.3 - PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE
For the Github or Debian package setups, I run strelaysrv using the following command:
strelaysrv -status-srv="" -pools="" -debug
For the Docker setups, run these commands:
apk add docker
apk add docker-compose
docker pull syncthing/relasrv
I use this docker-compose.yml file:
version: '1.27'
services:
syncthing:
image: syncthing/relaysrv
container_name: syncthing-relay
hostname: syncthing-relay
environment:
- PUID=1000
- PGID=1000
network_mode: host
restart: unless-stopped
entrypoint: ["/bin/entrypoint.sh", "/bin/strelaysrv", "status-srv", "\"\"" , "-pools", "\"\"", "-debug"]
And run it with:
sudo docker-compose up
For all setups, I use UFW to open port 22067 with the following commands:
sudo ufw allow 22067/tcp
sudo ufw enable
sudo reboot
On my phone and computer, I use the following address in the web interface under:
Remote Deivces
Edit Device
Advanced
Addresses
relay://192.168.1.1:22067/
For all setups, the relay seems to start up fine. My phone and computer IP addresses show up in the relay logs started on the (LAN). I don’t think I have made a connection to my phone and computer to my (WAN) DreamHost setups yet, although I can always ping my DreamHost instance.
For the (LAN) setups, the closest I have got to making a connection are with setups (1.) and (7.). Both relays show similar logs. The Relay log says “use of closed network connection” many times, which I am not sure how to interpret.
Questions:
- Can anyone point out obvious mistakes in my setup?
- Does “use of closed network connection” mean that my setup is incorrect?
- What can I do to get a simple LAN relay working? Anything is fine. Once I have an example working, I can figure it out from there.
- Why is the Github version (v1.22.1) behind the Docker version (v1.27.7)? Is there somewhere I can download the non-Docker v1.27.7 version?
Thank you for any advice! Syncthing is awesome.
Relay log for setup (7.), though setup (1.) is virtually the same:
./strelaysrv -status-srv="" -pools="" -debug
2024/05/18 11:52:02 main.go:141: strelaysrv v1.22.1 "Fermium Flea" (go1.19.2 linux-arm64) teamcity@build.syncthing.net 2022-11-02 06:27:53 UTC
2024/05/18 11:52:02 main.go:147: Connection limit 838860
2024/05/18 11:52:02 main.go:186: ID: RELAY-RELAY-RELAY-RELAY-RELAY-RELAY-RELAY-RELAY
2024/05/18 11:52:02 main.go:259: URI: relay://0.0.0.0:22067/?id=RELAY-RELAY-RELAY-RELAY-RELAY-RELAY-RELAY-RELAY&networkTimeout=2m0s&pingInterval=1m0s
2024/05/18 11:52:11 listener.go:48: Listener accepted connection from 192.168.1.3:42996 tls true
2024/05/18 11:52:11 listener.go:117: Message protocol.ConnectRequest from PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE
2024/05/18 11:52:11 listener.go:175: PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE is looking for COMP-COMP-COMP-COMP-COMP-COMP-COMP-COMP which does not exist
2024/05/18 11:52:11 listener.go:232: Closing connection PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE: read tcp 192.168.1.1:22067->192.168.1.3:42996: use of closed network connection
2024/05/18 11:52:26 listener.go:48: Listener accepted connection from 192.168.1.3:43610 tls true
2024/05/18 11:52:26 listener.go:117: Message protocol.ConnectRequest from PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE
2024/05/18 11:52:26 listener.go:175: PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE is looking for COMP-COMP-COMP-COMP-COMP-COMP-COMP-COMP which does not exist
2024/05/18 11:52:26 listener.go:232: Closing connection PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE: read tcp 192.168.1.1:22067->192.168.1.3:43610: use of closed network connection
2024/05/18 11:52:31 listener.go:48: Listener accepted connection from 192.168.1.3:43830 tls true
2024/05/18 11:52:31 listener.go:117: Message protocol.ConnectRequest from PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE
2024/05/18 11:52:31 listener.go:175: PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE is looking for COMP-COMP-COMP-COMP-COMP-COMP-COMP-COMP which does not exist
2024/05/18 11:52:31 listener.go:232: Closing connection PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE: read tcp 192.168.1.1:22067->192.168.1.3:43830: use of closed network connection
2024/05/18 11:52:36 listener.go:48: Listener accepted connection from 192.168.1.3:44036 tls true
2024/05/18 11:52:36 listener.go:117: Message protocol.ConnectRequest from PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE
2024/05/18 11:52:36 listener.go:175: PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE is looking for COMP-COMP-COMP-COMP-COMP-COMP-COMP-COMP which does not exist
2024/05/18 11:52:36 listener.go:232: Closing connection PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE: read tcp 192.168.1.1:22067->192.168.1.3:44036: use of closed network connection
2024/05/18 11:52:44 listener.go:48: Listener accepted connection from 192.168.1.3:44380 tls true
2024/05/18 11:52:44 listener.go:117: Message protocol.ConnectRequest from PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE
2024/05/18 11:52:44 listener.go:175: PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE is looking for COMP-COMP-COMP-COMP-COMP-COMP-COMP-COMP which does not exist
2024/05/18 11:52:44 listener.go:232: Closing connection PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE: read tcp 192.168.1.1:22067->192.168.1.3:44380: use of closed network connection
2024/05/18 11:52:47 listener.go:48: Listener accepted connection from 192.168.1.2:25362 tls true
2024/05/18 11:52:47 listener.go:117: Message protocol.ConnectRequest from COMP-COMP-COMP-COMP-COMP-COMP-COMP-COMP
2024/05/18 11:52:47 listener.go:175: COMP-COMP-COMP-COMP-COMP-COMP-COMP-COMP is looking for PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE which does not exist
2024/05/18 11:52:47 listener.go:232: Closing connection COMP-COMP-COMP-COMP-COMP-COMP-COMP-COMP: read tcp 192.168.1.1:22067->192.168.1.2:25362: use of closed network connection
2024/05/18 11:52:55 listener.go:48: Listener accepted connection from 192.168.1.2:25414 tls true
2024/05/18 11:52:55 listener.go:117: Message protocol.ConnectRequest from COMP-COMP-COMP-COMP-COMP-COMP-COMP-COMP
2024/05/18 11:52:55 listener.go:175: COMP-COMP-COMP-COMP-COMP-COMP-COMP-COMP is looking for PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE which does not exist
2024/05/18 11:52:55 listener.go:232: Closing connection COMP-COMP-COMP-COMP-COMP-COMP-COMP-COMP: read tcp 192.168.1.1:22067->192.168.1.2:25414: use of closed network connection
2024/05/18 11:53:00 listener.go:48: Listener accepted connection from 192.168.1.3:44994 tls true
2024/05/18 11:53:00 listener.go:117: Message protocol.ConnectRequest from PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE
2024/05/18 11:53:00 listener.go:175: PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE is looking for COMP-COMP-COMP-COMP-COMP-COMP-COMP-COMP which does not exist
2024/05/18 11:53:00 listener.go:232: Closing connection PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE: read tcp 192.168.1.1:22067->192.168.1.3:44994: use of closed network connection
2024/05/18 11:53:00 listener.go:48: Listener accepted connection from 192.168.1.2:25448 tls true
2024/05/18 11:53:00 listener.go:117: Message protocol.ConnectRequest from COMP-COMP-COMP-COMP-COMP-COMP-COMP-COMP
2024/05/18 11:53:00 listener.go:175: COMP-COMP-COMP-COMP-COMP-COMP-COMP-COMP is looking for PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE which does not exist
2024/05/18 11:53:00 listener.go:232: Closing connection COMP-COMP-COMP-COMP-COMP-COMP-COMP-COMP: EOF
2024/05/18 11:53:05 listener.go:48: Listener accepted connection from 192.168.1.2:25490 tls true
2024/05/18 11:53:05 listener.go:117: Message protocol.ConnectRequest from COMP-COMP-COMP-COMP-COMP-COMP-COMP-COMP
2024/05/18 11:53:05 listener.go:175: COMP-COMP-COMP-COMP-COMP-COMP-COMP-COMP is looking for PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE which does not exist
2024/05/18 11:53:05 listener.go:232: Closing connection COMP-COMP-COMP-COMP-COMP-COMP-COMP-COMP: read tcp 192.168.1.1:22067->192.168.1.2:25490: use of closed network connection
2024/05/18 11:53:13 listener.go:48: Listener accepted connection from 192.168.1.2:25545 tls true
2024/05/18 11:53:13 listener.go:117: Message protocol.ConnectRequest from COMP-COMP-COMP-COMP-COMP-COMP-COMP-COMP
2024/05/18 11:53:13 listener.go:175: COMP-COMP-COMP-COMP-COMP-COMP-COMP-COMP is looking for PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE which does not exist
2024/05/18 11:53:13 listener.go:232: Closing connection COMP-COMP-COMP-COMP-COMP-COMP-COMP-COMP: read tcp 192.168.1.1:22067->192.168.1.2:25545: use of closed network connection
2024/05/18 11:53:29 listener.go:48: Listener accepted connection from 192.168.1.2:25648 tls true
2024/05/18 11:53:29 listener.go:117: Message protocol.ConnectRequest from COMP-COMP-COMP-COMP-COMP-COMP-COMP-COMP
2024/05/18 11:53:29 listener.go:175: COMP-COMP-COMP-COMP-COMP-COMP-COMP-COMP is looking for PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE-PHONE which does not exist
2024/05/18 11:53:29 listener.go:232: Closing connection COMP-COMP-COMP-COMP-COMP-COMP-COMP-COMP: read tcp 192.168.1.1:22067->192.168.1.2:25648: use of closed network connection
