I have computers on a LAN: Linux, Windows 7, Windows XP. I use the old XP as a print and file server. I synchronize directories in these computers with one another and with Windows 7 computers on the internet. BitTorrent Sync (Beta) has no problems, but Syncthing has. Topology: Cabled LAN with a Cisco Linksys router, ADSL connection to the internet. A subset of the topology looks like this: Fuji(W7)—Router—Alina(XP) Router—Internet—Opti(W7) The router forwards port 22000 (TCP) and port 21025 (UDP). Often, but not always, Syncthing finds an UPnP device, albeit with a malformed UUID string, but it uses it. The Window Firewall allows Syncthing to use TCP and UDP. Syncthing in Fuji and Alina see each other and can sync. Syncthing in Fuji and Opti see each other and can sync. Syncthing in Alina and Opti cannot establish contact.
As Fuji can find Opti but Alina cannot, and the connections are equivalently set up, the problem can hardly be in Opti but should be in Alina.
Alina is a slower computer than Fuji. That may be the point, if the Syncthing protocol times out before a response has been received or processed. On Syncthing startup, nothing is said about unsuccessful connection attempts in the console window, but I can see that the Alina port that Syncthing uses to communicate with Opti’s port 22000 comes to state Sent but not to state Established. I guess that the expected response from Opti does not come in due time. As the remote IP address is known, at least some kind of basic communication must have been established.
Unfortunately, now and then also Fuji cannot find Opti, maybe for the same, never clarified, reason.
Timeout problems also occur in Fuji(W7) from time to time, although Opti is up and running, for example, "[D2ISY] 09:39:14 INFO: Connection to XYZ… closed: WSARecv tcp 192.168.1.100:22000: An existing connection was forcibly closed by the remote host.“ or ”[D2ISY] 09:43:33 INFO: Connection to XYZ… closed: WSARecv tcp 192.168.1.100:22000: An established connection was aborted by the software in your host machine.“ or "D2ISY] 19:42:41 INFO: Connection to 5HHF6XN-4IIFHDD-3DL5EJM-5EIC42T-QSBDROY-N7H3LL4-ZTT5U26-UNIYOQB closed: ping timeout”. A few minutes later the connection is reestablished. Now and then a message flashes in the GUI. It has a red bar at the top and says something about lost connection, but it disappears after l second or less, so I have never been able to read the whole text. But the connection is not lost, and there comes no message in the console window.
What I have seen makes me suspect that underlying problem is that Syncthing has one or more too short timeouts. In contrast to VoIP, file synchronization isn’t time-critical, so why not implement more patience?
When using file synchronization programs, the topology and the involved directories are basically static. The same fellow computers are expected to sync with one another in the same way every day. Sometimes, they cannot come into contact. Then its interesting to find out why they failed. The reason why they gave up should be displayed in the console window and logged, at least the first few failing attempts, so the problem can be investigated.
Based on this experience I suggest that the development team considers the possibility to
- Use longer timeouts than currently (v0.10.29), maybe optionally settable by the user.
- Supply diagnostic information about why connection attempts fail.
Please do not say just that I should upgrade from outdated hardware. In the world there are thousands or millions of XP computers that are potential Syncthing hosts.
