Issues with existing dataset (Turenas Scale)
Truenas Scale ElectricEel-24.10.2
Syncthing App Version:1.29.2 Version:1.1.11
I have a existing dataset with all my pictures on it. This is also used by Immich. I am trying to use syncthing so I can create a backup on my desktop.
I believe its a permission issue, but with tons of searching and attempts, I cannot find a solution.
Syncthing configuration additional storage Host path in Truenas is set to /mnt/Storage/pictures
Mount path is /sync_pictures
When using the web ui to add this “pictures” dataset, I have entered Folder Label as “sync_pictures” and Folder Path as “/mnt/Storage/pictures”
I get the following errors
2025-02-17 20:20:31: Failed to create folder root directory: mkdir /mnt/Storage: permission denied
2025-02-17 20:20:31: Error on folder "sync_pictures" (grpa5-nercb): folder path missing
Can anyone tell me where I am going wrong? pictures dataset is also a smb share, and I have given permission to ‘apps’ with full control.
I suspect you want to give Syncthing the mount path instead (/sync_pictures).
Tried and doesn’t change anything.
Other suggestions?
Not really, other than understand how permissions and volumes work on your system, sorry. :confused:
Apps for TrueNAS Scale are all in Docker/OCI containers, so you’ll have to sort out accessing the storage from the TrueNAS side into your Syncthing app container.
There have been a number of similar questions on this forum: https://forum.syncthing.net/search?q=truenas+scale
