A device has changed its friendly name. On the Android app, I’ve erased that device’s friendly name in order to refresh it but it has been replaced with the short ID instead. Is there a way to refresh it ?
Yes. Type it in manually. ![]()
I think it will refresh the name when establishing a new connection. Just erase the name, then pause and unpause the connection (which will force the devices to disconnect and reconnect).
Let’s say I’m lazy and dyslexic.
It worked ! Very helpful, thanks. ![]()
