ok,
I exported, My Config and uninstalled 11.2
Installed 11.6RC
Imported Config
Exited Syncthing
Started Syncthing
All files rescanned and A-OK.
All working well.
ok,
Installed 11.6RC
Imported Config
Exited Syncthing
Started Syncthing
All working well.
@mfya, I discovered a way of doing it on Chrome. Access this URL:
chrome://flags/#allow-insecure-localhost
and click on Enable. You need to restart Chrome after that. VoilĂ , now we can surf ST Web interface without that annoying warning about invalid certificate.
PS: I found the answer in this article
More feedback - mostly positive:
@Zillode and @Nutomic The new official version 0.6.0 looks terrific. On one of my Android devices I just did a direct version update (using Google PlayStore) from the previous âofficialâ version.
Process was flawless. Nice job - and thank you.
One correction from my earlier post. When I installed 0.11-6RC on top of 0.11-3 I did end up with 2 installed versions, just like you did. Sorry - I didnât notice this potential issue until I re-read your post and checked.
One of the 2 installed versions had my data attached (several GB) and the other had virtually no data, so I uninstalled the version without data - and all was fine after that. (Looks like uninstall old > install new is a more reliable method than install on top of when dealing with these test and debug versions)
Then I did an export config, uninstalled 0-11-6RC, installed the new âOfficialâ 0.6.0, followed by an import. All is working.
@marcelpaulo: thanks for the chrome explanation.
@Zillode and @Nutomic: I second @NickPyz: this looks terrific. I installed in one device (Android 4.4.2, stock) and Iâve checked CPU usage, and when the UI is closed, CPU usage is 2% or less (10 to 14% if UI kept on the foreground).
For those that have used the previous beta apk releases by @Zillode, I first tried removing the beta while keeping the data doing (from adb shell) pm uninstall -k com.nutomic.syncthingandroid but the installer kept complaining about the the version being incompatible. So I had to do a full uninstall (i.e., without the -k).
Thanks, added to the wiki
@Zillode, wonât 0.6.0 hit F-Droid ?
it will, takes a day before f-droid checks for new tags
Thanks for shedding light !
0.6.0 was finally picked by F-Droid ! My upgrade path was similar to @NickPyzâs, with one difference: after generating the keys, ST crashed and kept crashing when I tried to start it, so I had to reboot the phone. This difference aside, after importing the configuration, ST on the phone connected and synced without problems with ST 0.11.2 on my Xubuntu 15.04 laptop.
I took 5-min long top readings, for comparison with previous builds: gui on the background, and no gui.
Thanks, @Zillode, for all the sweat poured into this new release !
