I have it set up 1-way because I’m a bit afraid of data loss. But I still need a means to send data back which is why I’ll use a single file for that. Is there a way ot set that up?
Also is there a way to permit device B to add files, but not usually delete them unless there is strong reason to? The strong reason would be that I create or delete a file with the same path in device A.
