Hi there, Using syncthing-android 0.9.8 version, and SyncThing v0.14.25, on a Sony Xperia Z3 Compact.
I was visiting relatives and set a low outgoing rate limit (30KiB) as a temporary measure. I appear to be unable to set it back to something more sane - am I missing something?
If I go into the settings and SyncThing Options, then Outgoing Rate Limit it shows me 30 Ki/s. If I overtype it, it tells me I need to restart - so I press restart now, and when it comes back the limit is set to 30 again.
It’s going to take a while to back up the 17GB of photos I have at this rate
Am I missing something? Is it possible to manually edit the config file to make the change? Without root access I mean - I’ve never rooted the device.
Thanks, Chris
