Is it possible to change untrusted/encryption passwords?
After initially sharing a folder with an untrusted device and establishing a password, is it possible to subsequently change the password? Does it require re-adding the folder and/or re-syncing the data? Thank you.
It requires re-syncing the data, and at minimum removing the folder (and all data) and re-adding it again on the receive-encrypted side.
