Just putting this out there as i’m not calling it a bug. But i’ve noticed a job thats now plodding along where it used to be 15Mbps, now it’s a lot less
I did a speed test at the sending end and thats 20Mb down. It’s set up as a direct connection, not via relays.
On the sending side you need upstream, downstream matters on the receiving end.
If network bandwith isn’t maxed out, it may be other stuff that can’t keep up - for example, syncthing creates temp files and hashes data. If the system is not fast enough this slows down progress. A common slowdown factor is “lots of small files”.
This is how it looks for me. I personally would say it’s the same as usual, altough I haven’t looked much.
Sorry, I meant uploading, as in down to me. I have 70 coming in. Wrong wording. However I went to another office and did a test file of 320Mb. Again, this is a send only site and got this…
This is a fiber site of 70/20 and I would be expecting higher transfers. I have my setup to come directly to me and not via any relays.
You can turn off upgrades by opening the GUI, go to Actions -> Settings -> General -> Automatic upgrades. Another way is to set an enviroment variable (STNOUPGRADE, see the docs).
I’ve done further testing taking both end back to 1.2.0 rc.1 and I still get a slow connection. I have restarted both routers and get the same slow speed. So I don’t know why it’s dropped. I don’t therefore feel it’s a bug in the current release (not that I said it was in the first place), but it did seem coincidental.
There’s a lot of reason why Syncthing might not be maxing out the network bandwidth (disk io, cpu). There’s lots of information out there in threads people asking the same thing (“why is Syncthing bandwidth lower than what a speed test reports?”).
