Invisible out of sync items
On my peer it shows – and it has been like that over a week, a stale progress of syncing some items that probably do not exist (since they don’t show in the UI)
On the screenshot you see the Out of Sync Items UI and in the right bottom corner the device information it relates to.
Pause and unpause on either device did not work. I also tried deleting the mac-mini device.
This is a known issue. At this point, I would suggest to upgrade to Syncthing v2 and see if the problem disappears “naturally” with the new database.
