2022-06-29 14:56:15 My ID: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
2022-06-29 14:56:16 Single thread SHA256 performance is 168 MB/s using minio/sha256-simd (159 MB/s using crypto/sha256).
2022-06-29 14:56:16 Hashing performance is 150.30 MB/s
2022-06-29 14:56:16 Starting deadlock detector with 20m0s timeout
2022-06-29 14:56:16 Overall send rate is unlimited, receive rate is unlimited
2022-06-29 14:56:16 TCP listener ([::]:22000) starting
2022-06-29 14:56:16 Relay listener (dynamic+https://relays.syncthing.net/endpoint) starting
2022-06-29 14:56:16 Anonymous usage reporting is always enabled for candidate releases.
2022-06-29 14:56:16 Using discovery mechanism: global discovery server https://discovery.syncthing.net/v2/?noannounce&id=XXXXXXXXXX
2022-06-29 14:56:16 Using discovery mechanism: global discovery server https://discovery-v4.syncthing.net/v2/?nolookup&id=XXXXXXXXXX
2022-06-29 14:56:16 ...
2022-06-29 15:29:37 discover: Replaced address 0.0.0.0 in quic://0.0.0.0:22000 to get quic://[fe80::988a:e8ff:fec5:4949%25ens18]:22000
2022-06-29 15:29:37 discover: Accepted address quic://192.168.178.91:22000 verbatim
2022-06-29 15:29:37 discover: Accepted address quic://XXXXXXXXXX:22000 verbatim
2022-06-29 15:29:37 recv 426 bytes from 192.168.178.91:39445
2022-06-29 15:29:37 discover: Received local announcement from 192.168.178.91:39445 for XXXXXXXXXX
2022-06-29 15:29:37 discover: Registering addresses for XXXXXXXXXX
2022-06-29 15:29:37 discover: Reconstructed URL is &url.URL{Scheme:"tcp", Opaque:"", User:(*url.Userinfo)(nil), Host:"192.168.178.91:22000", Path:"", RawPath:"", ForceQuery:false, RawQuery:"", Fragment:"", RawFragment:""}
2022-06-29 15:29:37 discover: Replaced address 0.0.0.0 in tcp://0.0.0.0:22000 to get tcp://192.168.178.91:22000
2022-06-29 15:29:37 discover: Accepted address tcp://192.168.178.91:22000 verbatim
2022-06-29 15:29:37 discover: Reconstructed URL is &url.URL{Scheme:"tcp", Opaque:"", User:(*url.Userinfo)(nil), Host:"192.168.178.91:0", Path:"", RawPath:"", ForceQuery:false, RawQuery:"", Fragment:"", RawFragment:""}
2022-06-29 15:29:37 discover: Replaced address 0.0.0.0 in tcp://0.0.0.0:0 to get tcp://192.168.178.91:0
2022-06-29 15:29:37 discover: Accepted address relayXXX:22067/?globalLimitBps=0&id=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX&networkTimeout=2m0s&pingInterval=1m0s&providedBy=https%3A%2F%2Fwww.sthomann.ch&sessionLimitBps=0&statusAddr=%3A22070 verbatim
2022-06-29 15:29:37 discover: Reconstructed URL is &url.URL{Scheme:"quic", Opaque:"", User:(*url.Userinfo)(nil), Host:"192.168.178.91:22000", Path:"", RawPath:"", ForceQuery:false, RawQuery:"", Fragment:"", RawFragment:""}
2022-06-29 15:29:37 discover: Replaced address 0.0.0.0 in quic://0.0.0.0:22000 to get quic://192.168.178.91:22000
2022-06-29 15:29:39 http: GET "/rest/system/status": status 200, 2867 bytes in 0.46 ms
2022-06-29 15:29:39 http: GET "/rest/system/connections": status 200, 895 bytes in 0.09 ms
2022-06-29 15:29:39 http: GET "/rest/system/discovery": status 200, 756 bytes in 0.07 ms
2022-06-29 15:29:39 http: GET "/rest/system/error": status 200, 759 bytes in 0.10 ms
2022-06-29 15:29:46 sent 344 bytes to [ff12::8384]:21027 on ens18
2022-06-29 15:29:46 recv 344 bytes from [fe80::405c:c5ff:fe7e:672d%ens18]:60231
2022-06-29 15:29:46 discover: Received local announcement from [fe80::405c:c5ff:fe7e:672d%ens18]:60231 for XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
2022-06-29 15:29:46 addresses: [192.168.178.255]
2022-06-29 15:29:46 sent 344 bytes to 192.168.178.255:21027
2022-06-29 15:29:46 recv 344 bytes from 192.168.178.80:36052
2022-06-29 15:29:46 discover: Received local announcement from 192.168.178.80:36052 for XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
2022-06-29 15:29:49 http: GET "/rest/system/discovery": status 200, 756 bytes in 0.07 ms
2022-06-29 15:29:49 http: GET "/rest/system/status": status 200, 2867 bytes in 0.62 ms
2022-06-29 15:29:49 http: GET "/rest/system/error": status 200, 759 bytes in 0.06 ms
2022-06-29 15:29:49 http: GET "/rest/system/connections": status 200, 895 bytes in 0.13 ms
2022-06-29 15:29:59 http: GET "/rest/system/discovery": status 200, 756 bytes in 0.13 ms
2022-06-29 15:29:59 http: GET "/rest/system/status": status 200, 2867 bytes in 0.72 ms
2022-06-29 15:29:59 http: GET "/rest/system/error": status 200, 759 bytes in 0.15 ms
2022-06-29 15:29:59 http: GET "/rest/system/connections": status 200, 895 bytes in 0.09 ms
2022-06-29 15:30:00 StaticClient:0xc000ab5c40@relay://XXXXXXXXXX:22067/?globalLimitBps=0&id=XXXXXXXXXXO&networkTimeout=2m0s&pingInterval=1m0s&providedBy=dmndsh&sessionLimitBps=0&statusAddr=%3A22070 received message protocol.Ping
2022-06-29 15:30:00 StaticClient:0xc000ab5c40@relay://XXXXXXXXXX:22067/?globalLimitBps=0&id=XXXXXXXXXXO&networkTimeout=2m0s&pingInterval=1m0s&providedBy=dmndsh&sessionLimitBps=0&statusAddr=%3A22070 sent pong
2022-06-29 15:30:00 http: GET "/rest/events?since=18": status 200, 3 bytes in 60000.28 ms
2022-06-29 15:30:02 handle ping message
2022-06-29 15:30:02 XXXXXXXXXX ping -> after 1m29.999708834s
2022-06-29 15:30:02 Writing ping
2022-06-29 15:30:02 wrote 8 bytes on the wire (2 bytes length, 2 bytes header, 4 bytes message length, 0 bytes message), err=<nil>
2022-06-29 15:30:07 recv 426 bytes from [fe80::988a:e8ff:fec5:4949%ens18]:33253
2022-06-29 15:30:07 recv 426 bytes from 192.168.178.91:39445
2022-06-29 15:30:07 discover: Received local announcement from 192.168.178.91:39445 for XXXXXXXXXX
2022-06-29 15:30:07 discover: Registering addresses for XXXXXXXXXX
2022-06-29 15:30:07 discover: Reconstructed URL is &url.URL{Scheme:"tcp", Opaque:"", User:(*url.Userinfo)(nil), Host:"192.168.178.91:22000", Path:"", RawPath:"", ForceQuery:false, RawQuery:"", Fragment:"", RawFragment:""}
2022-06-29 15:30:07 discover: Replaced address 0.0.0.0 in tcp://0.0.0.0:22000 to get tcp://192.168.178.91:22000
2022-06-29 15:30:07 discover: Accepted address tcp://192.168.178.91:22000 verbatim
2022-06-29 15:30:07 discover: Reconstructed URL is &url.URL{Scheme:"tcp", Opaque:"", User:(*url.Userinfo)(nil), Host:"192.168.178.91:0", Path:"", RawPath:"", ForceQuery:false, RawQuery:"", Fragment:"", RawFragment:""}
2022-06-29 15:30:07 discover: Replaced address 0.0.0.0 in tcp://0.0.0.0:0 to get tcp://192.168.178.91:0
2022-06-29 15:30:07 discover: Accepted address relayXXX:22067/?globalLimitBps=0&id=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX&networkTimeout=2m0s&pingInterval=1m0s&providedBy=https%3A%2F%2Fwww.sthomann.ch&sessionLimitBps=0&statusAddr=%3A22070 verbatim
2022-06-29 15:30:07 discover: Reconstructed URL is &url.URL{Scheme:"quic", Opaque:"", User:(*url.Userinfo)(nil), Host:"192.168.178.91:22000", Path:"", RawPath:"", ForceQuery:false, RawQuery:"", Fragment:"", RawFragment:""}
2022-06-29 15:30:07 discover: Replaced address 0.0.0.0 in quic://0.0.0.0:22000 to get quic://192.168.178.91:22000
2022-06-29 15:30:07 discover: Accepted address quic://192.168.178.91:22000 verbatim
2022-06-29 15:30:07 discover: Accepted address quic://XXXXXXXXXX:22000 verbatim
2022-06-29 15:30:07 discover: Received local announcement from [fe80::988a:e8ff:fec5:4949%ens18]:33253 for XXXXXXXXXX
2022-06-29 15:30:07 discover: Reconstructed URL is &url.URL{Scheme:"tcp", Opaque:"", User:(*url.Userinfo)(nil), Host:"[fe80::988a:e8ff:fec5:4949%ens18]:22000", Path:"", RawPath:"", ForceQuery:false, RawQuery:"", Fragment:"", RawFragment:""}
2022-06-29 15:30:07 discover: Replaced address 0.0.0.0 in tcp://0.0.0.0:22000 to get tcp://[fe80::988a:e8ff:fec5:4949%25ens18]:22000
2022-06-29 15:30:07 discover: Reconstructed URL is &url.URL{Scheme:"tcp", Opaque:"", User:(*url.Userinfo)(nil), Host:"[fe80::988a:e8ff:fec5:4949%ens18]:0", Path:"", RawPath:"", ForceQuery:false, RawQuery:"", Fragment:"", RawFragment:""}
2022-06-29 15:30:07 discover: Replaced address 0.0.0.0 in tcp://0.0.0.0:0 to get tcp://[fe80::988a:e8ff:fec5:4949%25ens18]:0
2022-06-29 15:30:07 discover: Reconstructed URL is &url.URL{Scheme:"quic", Opaque:"", User:(*url.Userinfo)(nil), Host:"[fe80::988a:e8ff:fec5:4949%ens18]:22000", Path:"", RawPath:"", ForceQuery:false, RawQuery:"", Fragment:"", RawFragment:""}
2022-06-29 15:30:07 discover: Replaced address 0.0.0.0 in quic://0.0.0.0:22000 to get quic://[fe80::988a:e8ff:fec5:4949%25ens18]:22000
2022-06-29 15:30:09 http: GET "/rest/system/connections": status 200, 895 bytes in 0.13 ms
2022-06-29 15:30:09 http: GET "/rest/system/discovery": status 200, 756 bytes in 0.61 ms
2022-06-29 15:30:09 http: GET "/rest/system/status": status 200, 2867 bytes in 0.62 ms
2022-06-29 15:30:09 http: GET "/rest/system/error": status 200, 759 bytes in 0.06 ms
2022-06-29 15:30:16 sent 344 bytes to [ff12::8384]:21027 on ens18
2022-06-29 15:30:16 recv 344 bytes from [fe80::405c:c5ff:fe7e:672d%ens18]:60231
2022-06-29 15:30:16 discover: Received local announcement from [fe80::405c:c5ff:fe7e:672d%ens18]:60231 for XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
2022-06-29 15:30:16 addresses: [192.168.178.255]
2022-06-29 15:30:16 sent 344 bytes to 192.168.178.255:21027
2022-06-29 15:30:16 recv 344 bytes from 192.168.178.80:36052
2022-06-29 15:30:16 discover: Received local announcement from 192.168.178.80:36052 for XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
2022-06-29 15:30:16 Connection loop
2022-06-29 15:30:16 stats.DeviceStatisticsReference.GetLastSeen: XXXXXXXXXX 2022-06-29 15:29:16 +0000 UTC
2022-06-29 15:30:16 stats.DeviceStatisticsReference.GetLastConnectionDuration: XXXXXXXXXX 7428084485
2022-06-29 15:30:16 stats.DeviceStatisticsReference.WasSeen: XXXXXXXXXX
2022-06-29 15:30:16 Next connection loop in 1m0s
2022-06-29 15:30:19 http: GET "/rest/system/error": status 200, 759 bytes in 0.07 ms
2022-06-29 15:30:19 http: GET "/rest/system/connections": status 200, 895 bytes in 0.11 ms
2022-06-29 15:30:19 http: GET "/rest/system/discovery": status 200, 756 bytes in 0.07 ms
2022-06-29 15:30:19 http: GET "/rest/system/status": status 200, 2867 bytes in 0.75 ms
2022-06-29 15:30:29 http: GET "/rest/system/discovery": status 200, 756 bytes in 0.16 ms
2022-06-29 15:30:29 http: GET "/rest/system/error": status 200, 759 bytes in 0.07 ms
2022-06-29 15:30:29 http: GET "/rest/system/connections": status 200, 895 bytes in 0.16 ms
2022-06-29 15:30:29 http: GET "/rest/system/status": status 200, 2867 bytes in 1.11 ms
2022-06-29 15:30:37 recv 426 bytes from [fe80::988a:e8ff:fec5:4949%ens18]:33253
2022-06-29 15:30:37 discover: Received local announcement from [fe80::988a:e8ff:fec5:4949%ens18]:33253 for XXXXXXXXXX
2022-06-29 15:30:37 discover: Registering addresses for XXXXXXXXXX
2022-06-29 15:30:37 discover: Reconstructed URL is &url.URL{Scheme:"tcp", Opaque:"", User:(*url.Userinfo)(nil), Host:"[fe80::988a:e8ff:fec5:4949%ens18]:22000", Path:"", RawPath:"", ForceQuery:false, RawQuery:"", Fragment:"", RawFragment:""}
2022-06-29 15:30:37 discover: Replaced address 0.0.0.0 in tcp://0.0.0.0:22000 to get tcp://[fe80::988a:e8ff:fec5:4949%25ens18]:22000
2022-06-29 15:30:37 discover: Accepted address tcp://192.168.178.91:22000 verbatim
2022-06-29 15:30:37 discover: Reconstructed URL is &url.URL{Scheme:"tcp", Opaque:"", User:(*url.Userinfo)(nil), Host:"[fe80::988a:e8ff:fec5:4949%ens18]:0", Path:"", RawPath:"", ForceQuery:false, RawQuery:"", Fragment:"", RawFragment:""}
2022-06-29 15:30:37 discover: Replaced address 0.0.0.0 in tcp://0.0.0.0:0 to get tcp://[fe80::988a:e8ff:fec5:4949%25ens18]:0
2022-06-29 15:30:37 discover: Accepted address relayXXX:22067/?globalLimitBps=0&id=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX&networkTimeout=2m0s&pingInterval=1m0s&providedBy=https%3A%2F%2Fwww.sthomann.ch&sessionLimitBps=0&statusAddr=%3A22070 verbatim
2022-06-29 15:30:37 discover: Reconstructed URL is &url.URL{Scheme:"quic", Opaque:"", User:(*url.Userinfo)(nil), Host:"[fe80::988a:e8ff:fec5:4949%ens18]:22000", Path:"", RawPath:"", ForceQuery:false, RawQuery:"", Fragment:"", RawFragment:""}
2022-06-29 15:30:37 discover: Replaced address 0.0.0.0 in quic://0.0.0.0:22000 to get quic://[fe80::988a:e8ff:fec5:4949%25ens18]:22000
2022-06-29 15:30:37 discover: Accepted address quic://192.168.178.91:22000 verbatim
2022-06-29 15:30:37 discover: Accepted address quic://XXXXXXXXXX:22000 verbatim
2022-06-29 15:30:37 recv 426 bytes from 192.168.178.91:39445
2022-06-29 15:30:37 discover: Received local announcement from 192.168.178.91:39445 for XXXXXXXXXX
2022-06-29 15:30:37 discover: Reconstructed URL is &url.URL{Scheme:"tcp", Opaque:"", User:(*url.Userinfo)(nil), Host:"192.168.178.91:22000", Path:"", RawPath:"", ForceQuery:false, RawQuery:"", Fragment:"", RawFragment:""}
2022-06-29 15:30:37 discover: Replaced address 0.0.0.0 in tcp://0.0.0.0:22000 to get tcp://192.168.178.91:22000
2022-06-29 15:30:37 discover: Reconstructed URL is &url.URL{Scheme:"tcp", Opaque:"", User:(*url.Userinfo)(nil), Host:"192.168.178.91:0", Path:"", RawPath:"", ForceQuery:false, RawQuery:"", Fragment:"", RawFragment:""}
2022-06-29 15:30:37 discover: Replaced address 0.0.0.0 in tcp://0.0.0.0:0 to get tcp://192.168.178.91:0
2022-06-29 15:30:37 discover: Reconstructed URL is &url.URL{Scheme:"quic", Opaque:"", User:(*url.Userinfo)(nil), Host:"192.168.178.91:22000", Path:"", RawPath:"", ForceQuery:false, RawQuery:"", Fragment:"", RawFragment:""}
2022-06-29 15:30:37 discover: Replaced address 0.0.0.0 in quic://0.0.0.0:22000 to get quic://192.168.178.91:22000
2022-06-29 15:30:39 http: GET "/rest/system/error": status 200, 759 bytes in 0.07 ms
2022-06-29 15:30:39 http: GET "/rest/system/status": status 200, 2868 bytes in 0.48 ms
2022-06-29 15:30:39 http: GET "/rest/system/discovery": status 200, 756 bytes in 0.69 ms
2022-06-29 15:30:39 http: GET "/rest/system/connections": status 200, 895 bytes in 0.90 ms
2022-06-29 15:30:46 sent 344 bytes to [ff12::8384]:21027 on ens18
2022-06-29 15:30:46 addresses: [192.168.178.255]
2022-06-29 15:30:46 sent 344 bytes to 192.168.178.255:21027
2022-06-29 15:30:46 recv 344 bytes from 192.168.178.80:36052
2022-06-29 15:30:46 discover: Received local announcement from 192.168.178.80:36052 for XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
2022-06-29 15:30:46 recv 344 bytes from [fe80::405c:c5ff:fe7e:672d%ens18]:60231
2022-06-29 15:30:46 discover: Received local announcement from [fe80::405c:c5ff:fe7e:672d%ens18]:60231 for XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
2022-06-29 15:30:47 XXXXXXXXXX ping skipped after wr 44.999582627s
2022-06-29 15:30:49 http: GET "/rest/system/discovery": status 200, 756 bytes in 0.08 ms
2022-06-29 15:30:49 http: GET "/rest/system/connections": status 200, 895 bytes in 0.46 ms
2022-06-29 15:30:49 http: GET "/rest/system/status": status 200, 2867 bytes in 0.67 ms
2022-06-29 15:30:49 http: GET "/rest/system/error": status 200, 759 bytes in 0.06 ms
2022-06-29 15:30:59 http: GET "/rest/system/discovery": status 200, 756 bytes in 0.20 ms
2022-06-29 15:30:59 http: GET "/rest/system/connections": status 200, 895 bytes in 0.20 ms
2022-06-29 15:30:59 http: GET "/rest/system/status": status 200, 2867 bytes in 1.05 ms
2022-06-29 15:30:59 http: GET "/rest/system/error": status 200, 759 bytes in 0.06 ms
2022-06-29 15:31:00 StaticClient:0xc000ab5c40@relay://XXXXXXXXXX:22067/?globalLimitBps=0&id=XXXXXXXXXXO&networkTimeout=2m0s&pingInterval=1m0s&providedBy=dmndsh&sessionLimitBps=0&statusAddr=%3A22070 received message protocol.Ping
2022-06-29 15:31:00 StaticClient:0xc000ab5c40@relay://XXXXXXXXXX:22067/?globalLimitBps=0&id=XXXXXXXXXXO&networkTimeout=2m0s&pingInterval=1m0s&providedBy=dmndsh&sessionLimitBps=0&statusAddr=%3A22070 sent pong
2022-06-29 15:31:00 http: GET "/rest/events?since=18": status 200, 3 bytes in 60000.25 ms
2022-06-29 15:31:07 recv 426 bytes from 192.168.178.91:39445
2022-06-29 15:31:07 discover: Received local announcement from 192.168.178.91:39445 for XXXXXXXXXX
2022-06-29 15:31:07 discover: Registering addresses for XXXXXXXXXX
2022-06-29 15:31:07 discover: Reconstructed URL is &url.URL{Scheme:"tcp", Opaque:"", User:(*url.Userinfo)(nil), Host:"192.168.178.91:22000", Path:"", RawPath:"", ForceQuery:false, RawQuery:"", Fragment:"", RawFragment:""}
2022-06-29 15:31:07 discover: Replaced address 0.0.0.0 in tcp://0.0.0.0:22000 to get tcp://192.168.178.91:22000
2022-06-29 15:31:07 discover: Accepted address tcp://192.168.178.91:22000 verbatim
2022-06-29 15:31:07 discover: Reconstructed URL is &url.URL{Scheme:"tcp", Opaque:"", User:(*url.Userinfo)(nil), Host:"192.168.178.91:0", Path:"", RawPath:"", ForceQuery:false, RawQuery:"", Fragment:"", RawFragment:""}
2022-06-29 15:31:07 discover: Replaced address 0.0.0.0 in tcp://0.0.0.0:0 to get tcp://192.168.178.91:0
2022-06-29 15:31:07 discover: Accepted address relayXXX:22067/?globalLimitBps=0&id=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX&networkTimeout=2m0s&pingInterval=1m0s&providedBy=https%3A%2F%2Fwww.sthomann.ch&sessionLimitBps=0&statusAddr=%3A22070 verbatim
2022-06-29 15:31:07 discover: Reconstructed URL is &url.URL{Scheme:"quic", Opaque:"", User:(*url.Userinfo)(nil), Host:"192.168.178.91:22000", Path:"", RawPath:"", ForceQuery:false, RawQuery:"", Fragment:"", RawFragment:""}
2022-06-29 15:31:07 discover: Replaced address 0.0.0.0 in quic://0.0.0.0:22000 to get quic://192.168.178.91:22000
2022-06-29 15:31:07 discover: Accepted address quic://192.168.178.91:22000 verbatim
2022-06-29 15:31:07 discover: Accepted address quic://XXXXXXXXXX:22000 verbatim
2022-06-29 15:31:07 recv 426 bytes from [fe80::988a:e8ff:fec5:4949%ens18]:33253
2022-06-29 15:31:07 discover: Received local announcement from [fe80::988a:e8ff:fec5:4949%ens18]:33253 for XXXXXXXXXX
2022-06-29 15:31:07 discover: Reconstructed URL is &url.URL{Scheme:"tcp", Opaque:"", User:(*url.Userinfo)(nil), Host:"[fe80::988a:e8ff:fec5:4949%ens18]:22000", Path:"", RawPath:"", ForceQuery:false, RawQuery:"", Fragment:"", RawFragment:""}
2022-06-29 15:31:07 discover: Replaced address 0.0.0.0 in tcp://0.0.0.0:22000 to get tcp://[fe80::988a:e8ff:fec5:4949%25ens18]:22000
2022-06-29 15:31:07 discover: Reconstructed URL is &url.URL{Scheme:"tcp", Opaque:"", User:(*url.Userinfo)(nil), Host:"[fe80::988a:e8ff:fec5:4949%ens18]:0", Path:"", RawPath:"", ForceQuery:false, RawQuery:"", Fragment:"", RawFragment:""}
2022-06-29 15:31:07 discover: Replaced address 0.0.0.0 in tcp://0.0.0.0:0 to get tcp://[fe80::988a:e8ff:fec5:4949%25ens18]:0
2022-06-29 15:31:07 discover: Reconstructed URL is &url.URL{Scheme:"quic", Opaque:"", User:(*url.Userinfo)(nil), Host:"[fe80::988a:e8ff:fec5:4949%ens18]:22000", Path:"", RawPath:"", ForceQuery:false, RawQuery:"", Fragment:"", RawFragment:""}
2022-06-29 15:31:07 discover: Replaced address 0.0.0.0 in quic://0.0.0.0:22000 to get quic://[fe80::988a:e8ff:fec5:4949%25ens18]:22000
2022-06-29 15:31:09 http: GET "/rest/system/discovery": status 200, 756 bytes in 0.11 ms
2022-06-29 15:31:09 http: GET "/rest/system/status": status 200, 2867 bytes in 0.81 ms
2022-06-29 15:31:09 http: GET "/rest/system/error": status 200, 759 bytes in 0.10 ms
2022-06-29 15:31:09 http: GET "/rest/system/connections": status 200, 895 bytes in 0.08 ms
2022-06-29 15:31:16 sent 344 bytes to [ff12::8384]:21027 on ens18
2022-06-29 15:31:16 addresses: [192.168.178.255]
2022-06-29 15:31:16 sent 344 bytes to 192.168.178.255:21027
2022-06-29 15:31:16 recv 344 bytes from 192.168.178.80:36052
2022-06-29 15:31:16 discover: Received local announcement from 192.168.178.80:36052 for XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
2022-06-29 15:31:16 recv 344 bytes from [fe80::405c:c5ff:fe7e:672d%ens18]:60231
2022-06-29 15:31:16 discover: Received local announcement from [fe80::405c:c5ff:fe7e:672d%ens18]:60231 for XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
2022-06-29 15:31:16 Connection loop
2022-06-29 15:31:16 stats.DeviceStatisticsReference.GetLastSeen: XXXXXXXXXX 2022-06-29 15:30:16 +0000 UTC
2022-06-29 15:31:16 stats.DeviceStatisticsReference.GetLastConnectionDuration: XXXXXXXXXX 7428084485
2022-06-29 15:31:16 stats.DeviceStatisticsReference.WasSeen: XXXXXXXXXX
2022-06-29 15:31:16 Next connection loop in 1m0s
2022-06-29 15:31:17 XXXXXXXXXX last read within 1m15.001636359s
2022-06-29 15:31:19 http: GET "/rest/system/connections": status 200, 895 bytes in 0.11 ms
2022-06-29 15:31:19 http: GET "/rest/system/discovery": status 200, 756 bytes in 0.35 ms
2022-06-29 15:31:19 http: GET "/rest/system/status": status 200, 2867 bytes in 0.53 ms
2022-06-29 15:31:19 http: GET "/rest/system/error": status 200, 759 bytes in 0.05 ms
2022-06-29 15:31:29 http: GET "/rest/system/discovery": status 200, 756 bytes in 0.19 ms
2022-06-29 15:31:29 http: GET "/rest/system/status": status 200, 2867 bytes in 0.48 ms
2022-06-29 15:31:29 http: GET "/rest/system/error": status 200, 759 bytes in 0.07 ms
2022-06-29 15:31:29 http: GET "/rest/system/connections": status 200, 895 bytes in 0.22 ms
2022-06-29 15:31:32 handle ping message
2022-06-29 15:31:32 XXXXXXXXXX ping -> after 1m30.000119761s
2022-06-29 15:31:32 Writing ping
2022-06-29 15:31:32 wrote 8 bytes on the wire (2 bytes length, 2 bytes header, 4 bytes message length, 0 bytes message), err=<nil>
2022-06-29 15:31:37 recv 426 bytes from [fe80::988a:e8ff:fec5:4949%ens18]:33253
2022-06-29 15:31:37 discover: Received local announcement from [fe80::988a:e8ff:fec5:4949%ens18]:33253 for XXXXXXXXXX
2022-06-29 15:31:37 discover: Registering addresses for XXXXXXXXXX
2022-06-29 15:31:37 discover: Reconstructed URL is &url.URL{Scheme:"quic", Opaque:"", User:(*url.Userinfo)(nil), Host:"[fe80::988a:e8ff:fec5:4949%ens18]:22000", Path:"", RawPath:"", ForceQuery:false, RawQuery:"", Fragment:"", RawFragment:""}
2022-06-29 15:31:37 discover: Replaced address 0.0.0.0 in quic://0.0.0.0:22000 to get quic://[fe80::988a:e8ff:fec5:4949%25ens18]:22000
2022-06-29 15:31:37 discover: Accepted address quic://192.168.178.91:22000 verbatim
2022-06-29 15:31:37 discover: Accepted address quic://XXXXXXXXXX:22000 verbatim
2022-06-29 15:31:37 discover: Reconstructed URL is &url.URL{Scheme:"tcp", Opaque:"", User:(*url.Userinfo)(nil), Host:"[fe80::988a:e8ff:fec5:4949%ens18]:22000", Path:"", RawPath:"", ForceQuery:false, RawQuery:"", Fragment:"", RawFragment:""}
2022-06-29 15:31:37 discover: Replaced address 0.0.0.0 in tcp://0.0.0.0:22000 to get tcp://[fe80::988a:e8ff:fec5:4949%25ens18]:22000
2022-06-29 15:31:37 discover: Accepted address tcp://192.168.178.91:22000 verbatim
2022-06-29 15:31:37 discover: Reconstructed URL is &url.URL{Scheme:"tcp", Opaque:"", User:(*url.Userinfo)(nil), Host:"[fe80::988a:e8ff:fec5:4949%ens18]:0", Path:"", RawPath:"", ForceQuery:false, RawQuery:"", Fragment:"", RawFragment:""}
2022-06-29 15:31:37 discover: Replaced address 0.0.0.0 in tcp://0.0.0.0:0 to get tcp://[fe80::988a:e8ff:fec5:4949%25ens18]:0
2022-06-29 15:31:37 discover: Accepted address relayXXX:22067/?globalLimitBps=0&id=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX&networkTimeout=2m0s&pingInterval=1m0s&providedBy=https%3A%2F%2Fwww.sthomann.ch&sessionLimitBps=0&statusAddr=%3A22070 verbatim
2022-06-29 15:31:37 recv 426 bytes from 192.168.178.91:39445
2022-06-29 15:31:37 discover: Received local announcement from 192.168.178.91:39445 for XXXXXXXXXX
2022-06-29 15:31:37 discover: Reconstructed URL is &url.URL{Scheme:"tcp", Opaque:"", User:(*url.Userinfo)(nil), Host:"192.168.178.91:22000", Path:"", RawPath:"", ForceQuery:false, RawQuery:"", Fragment:"", RawFragment:""}
2022-06-29 15:31:37 discover: Replaced address 0.0.0.0 in tcp://0.0.0.0:22000 to get tcp://192.168.178.91:22000
2022-06-29 15:31:37 discover: Reconstructed URL is &url.URL{Scheme:"tcp", Opaque:"", User:(*url.Userinfo)(nil), Host:"192.168.178.91:0", Path:"", RawPath:"", ForceQuery:false, RawQuery:"", Fragment:"", RawFragment:""}
2022-06-29 15:31:37 discover: Replaced address 0.0.0.0 in tcp://0.0.0.0:0 to get tcp://192.168.178.91:0
2022-06-29 15:31:37 discover: Reconstructed URL is &url.URL{Scheme:"quic", Opaque:"", User:(*url.Userinfo)(nil), Host:"192.168.178.91:22000", Path:"", RawPath:"", ForceQuery:false, RawQuery:"", Fragment:"", RawFragment:""}
2022-06-29 15:31:37 discover: Replaced address 0.0.0.0 in quic://0.0.0.0:22000 to get quic://192.168.178.91:22000
2022-06-29 15:31:39 http: GET "/rest/system/discovery": status 200, 756 bytes in 0.13 ms
2022-06-29 15:31:39 http: GET "/rest/system/status": status 200, 2867 bytes in 1.21 ms
2022-06-29 15:31:39 http: GET "/rest/system/connections": status 200, 895 bytes in 0.10 ms
2022-06-29 15:31:39 http: GET "/rest/system/error": status 200, 759 bytes in 0.37 ms
2022-06-29 15:31:46 addresses: [192.168.178.255]
2022-06-29 15:31:46 sent 344 bytes to 192.168.178.255:21027
2022-06-29 15:31:46 recv 344 bytes from 192.168.178.80:36052
2022-06-29 15:31:46 sent 344 bytes to [ff12::8384]:21027 on ens18
2022-06-29 15:31:46 discover: Received local announcement from 192.168.178.80:36052 for XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
2022-06-29 15:31:46 recv 344 bytes from [fe80::405c:c5ff:fe7e:672d%ens18]:60231
2022-06-29 15:31:46 discover: Received local announcement from [fe80::405c:c5ff:fe7e:672d%ens18]:60231 for XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
2022-06-29 15:31:49 http: GET "/rest/system/discovery": status 200, 756 bytes in 0.18 ms
2022-06-29 15:31:49 http: GET "/rest/system/connections": status 200, 895 bytes in 0.93 ms
2022-06-29 15:31:49 http: GET "/rest/system/status": status 200, 2867 bytes in 0.98 ms
2022-06-29 15:31:49 http: GET "/rest/system/error": status 200, 759 bytes in 0.08 ms
2022-06-29 15:31:49 http: GET "/rest/system/debug": status 200, 1506 bytes in 0.11 ms
2022-06-29 15:31:49 parsing time "" as "2006-01-02T15:04:05Z07:00": cannot parse "" as "2006"
SYNCH SERVER
SYNCH SERVER
drwx------ 3 root root 4096 Jun 29 14:56 .
drwx------ 7 root root 4096 Jun 28 15:14 ..
-rw-r--r-- 1 root root 794 Jun 21 14:10 cert.pem
-rw------- 1 root root 9722 Jun 28 20:20 config.xml
-rw------- 1 root root 7300 Jun 21 14:13 config.xml.v0
-rw------- 1 root root 66 Jun 28 19:58 csrftokens.txt
-rw-r--r-- 1 root root 778 Jun 21 14:10 https-cert.pem
-rw------- 1 root root 288 Jun 21 14:10 https-key.pem
drwxr-xr-x 2 root root 4096 Jun 29 15:16 index-v0.14.0.db
-rw------- 1 root root 288 Jun 21 14:10 key.pem
-rw-r--r-- 1 root root 0 Jun 28 19:47 panic-20220628-194719.reported.log
-rw-r--r-- 1 root root 498421 Jun 28 20:40 panic-20220628-204011.reported.log
-rw-r--r-- 1 root root 0 Jun 29 14:43 panic-20220629-144323.reported.log
-rw-r--r-- 1 root root 498193 Jun 29 14:56 panic-20220629-145613.reported.log
