I wanted to install Syncthing on my RasppberryPi (operating system Ubuntu Server) and followed the installation steps from: https://apt.syncthing.net/. I’m yet not sure if the installation was actually succecssful.
Basically, the commands from the steps above were all executed but after that, when I type in syncthing, it gets stuck on the wy. Below is the log (note: before the last 4 log outputs, I manually aborted the procedure). Can anyone help me on what’s happened here?
pi@raspberrypi:~$ syncthing -verbose
[start] 2022/12/07 10:32:28 INFO: syncthing v1.22.2 "Fermium Flea" (go1.19.2 linux-arm) teamcity@build.syncthing.net 2022-11-28 03:48:37 UTC
[BOEUZ] 2022/12/07 10:32:29 INFO: My ID: BOEUZYY-54BD62B-KSVFTEW-AWMRX6V-KWINPHR-UJSFJJC-CKWQXDJ-LQ6KIAQ
[BOEUZ] 2022/12/07 10:32:30 INFO: Single thread SHA256 performance is 53 MB/s using minio/sha256-simd (53 MB/s using crypto/sha256).
[BOEUZ] 2022/12/07 10:32:30 VERBOSE: Starting up (/home/pi/.config/syncthing)
[BOEUZ] 2022/12/07 10:32:31 INFO: Hashing performance is 47.83 MB/s
[BOEUZ] 2022/12/07 10:32:31 INFO: Overall send rate is unlimited, receive rate is unlimited
[BOEUZ] 2022/12/07 10:32:31 INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) starting
[BOEUZ] 2022/12/07 10:32:31 INFO: QUIC listener ([::]:22000) starting
[BOEUZ] 2022/12/07 10:32:31 VERBOSE: Listen address quic://0.0.0.0:22000 resolution has changed: lan addresses: [quic://0.0.0.0:22000 quic://192.168.1.5:22000 quic://10.83.3.1:22000] wan addresses: [quic://0.0.0.0:22000]
[BOEUZ] 2022/12/07 10:32:31 INFO: TCP listener ([::]:22000) starting
[BOEUZ] 2022/12/07 10:32:31 VERBOSE: Listen address tcp://0.0.0.0:22000 resolution has changed: lan addresses: [tcp://0.0.0.0:22000 tcp://192.168.1.5:22000 tcp://10.83.3.1:22000] wan addresses: [tcp://0.0.0.0:0 tcp://0.0.0.0:22000]
[BOEUZ] 2022/12/07 10:32:31 INFO: Using discovery mechanism: global discovery server https://discovery.syncthing.net/v2/?noannounce&id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
[BOEUZ] 2022/12/07 10:32:31 INFO: Using discovery mechanism: global discovery server https://discovery-v4.syncthing.net/v2/?nolookup&id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
[BOEUZ] 2022/12/07 10:32:31 INFO: Using discovery mechanism: global discovery server https://discovery-v6.syncthing.net/v2/?nolookup&id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
[BOEUZ] 2022/12/07 10:32:31 INFO: Using discovery mechanism: IPv4 local broadcast discovery on port 21027
[BOEUZ] 2022/12/07 10:32:31 INFO: Using discovery mechanism: IPv6 local multicast discovery on address [ff12::8384]:21027
[BOEUZ] 2022/12/07 10:32:31 INFO: Ready to synchronize "Default Folder" (default) (sendreceive)
[BOEUZ] 2022/12/07 10:32:31 INFO: GUI and API listening on 127.0.0.1:8384
[BOEUZ] 2022/12/07 10:32:31 INFO: Access the GUI via the following URL: http://127.0.0.1:8384/
[BOEUZ] 2022/12/07 10:32:31 INFO: My name is "raspberrypi"
[BOEUZ] 2022/12/07 10:32:31 VERBOSE: Folder "default" is now scan-waiting
[BOEUZ] 2022/12/07 10:32:31 VERBOSE: Folder "default" is now scanning
[BOEUZ] 2022/12/07 10:32:31 VERBOSE: Startup complete
[BOEUZ] 2022/12/07 10:32:31 INFO: Completed initial scan of sendreceive folder "Default Folder" (default)
[BOEUZ] 2022/12/07 10:32:31 VERBOSE: Folder "default" is now idle
[BOEUZ] 2022/12/07 10:32:41 INFO: Detected 1 NAT service
[BOEUZ] 2022/12/07 10:32:50 INFO: quic://0.0.0.0:22000 detected NAT type: Port restricted NAT
[BOEUZ] 2022/12/07 10:32:50 INFO: quic://0.0.0.0:22000 resolved external address quic://186.151.24.133:21377 (via stun.syncthing.net:3478)
[BOEUZ] 2022/12/07 10:32:50 VERBOSE: Listen address quic://0.0.0.0:22000 resolution has changed: lan addresses: [quic://0.0.0.0:22000 quic://192.168.1.5:22000 quic://10.83.3.1:22000] wan addresses: [quic://0.0.0.0:22000 quic://186.151.24.133:21377]
[BOEUZ] 2022/12/07 10:33:48 INFO: Joined relay relay://104.245.38.195:22067
[BOEUZ] 2022/12/07 10:33:51 VERBOSE: Listen address dynamic+https://relays.syncthing.net/endpoint resolution has changed: lan addresses: [relay://104.245.38.195:22067/?globalLimitBps=51200&id=LARCFRF-B6CZRQD-JTWAK4K-HVRGQ5D-U4CY7MR-OY5QWLB-2MAWBSF-J2GGQQH&networkTimeout=2m0s&pingInterval=1m0s&providedBy=akame&sessionLimitBps=9600&statusAddr=%3A22070] wan addresses: [relay://104.245.38.195:22067/?globalLimitBps=51200&id=LARCFRF-B6CZRQD-JTWAK4K-HVRGQ5D-U4CY7MR-OY5QWLB-2MAWBSF-J2GGQQH&networkTimeout=2m0s&pingInterval=1m0s&providedBy=akame&sessionLimitBps=9600&statusAddr=%3A22070]
^C[monitor] 2022/12/07 11:08:51 INFO: Signal 2 received; exiting
[BOEUZ] 2022/12/07 11:08:51 INFO: QUIC listener ([::]:22000) shutting down
[BOEUZ] 2022/12/07 11:08:51 INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) shutting down
[BOEUZ] 2022/12/07 11:08:52 INFO: TCP listener ([::]:22000) shutting down
[BOEUZ] 2022/12/07 11:08:52 INFO: Exiting
wolfslair@raspberrypi:~$ ^C
wolfslair@raspberrypi:~$ Listen address dynamic+https:wolfslair@raspberrypi:~$ syncthing -verbose
[BOEUZ] 2022/12/07 10:32:30 VERBOSE: Starting up (/home/wolfslair/.config/syncthing)
