I get an INFO message on the server running syncthing: “Connected to myself at [ip address]:22000/tcp-client/TLS1.2-TLS_ECDHE-ECDSA_WITH_AES_256_GCM_SHA384 - should not happen.”
Any thoughts on why this is happening, is it a problem, and if so how to I fix it?
I read the thread, but I am not using port forwarding or global discovery. All of my workstations are pointed to the server at the 192.168.0.9:22000. The server is listening on tcp://0.0.0.0: 22000. We specifically don’t want to use any server outside our local network for security reasons.
Because the IP is hidden its not clear what address it connected to, if its not a local address then it was found via discovery which probably has UPnP setup.
The IP is internal. I do have Local Discovery enabled.
If I enter the IP address directly in the client workstation, do I still need discovery enabled?
On the workstation in Settings–>Connections–>Sync Protocol Listen Addresses, I have entered the server IP address: tcp://192.168.0.9:22000. Is this correct?
On the server in Settings–>Connections–>Sync Protocol Listen Addresses, I have entered tcp4://0.0.0.0:22000. Should this be blank or the actual LAN address of the server?
Forgive my questions as I am new to Syncthing and trying to pick up where a previous IT person left after they did the initial setup.
