Transferring a large file is much faster than transferring lots of small files. It would compact the small files together to increase the transfer rate and unpack on arrival. Do not necessarily use compression that can be slow on some devices.
You can adjust number of copiers in the config.xml to parallelize this better for a given folder. You can also raise the number of pullers, but make sure copiers do not exceed pullers and that there are always spare pullers available.
Thanks for your reply. What I have to add to the config.xml to increase the number of copiers and pullers?
There are settings for pullers copiers for each folder, you just need to increase them
Hi! Iâm new in the forum, but user of Syncthing for more than a year now. We use it in our small company.
I also experience this tiny files slow sync issue (I know itâs a topic that has been discussed in the forum several times). Iâm talking about folders which handle around 1.7M files, 217k folders, aprox. 170GB space (a mix of small and big files, but mostly small). Our main issue is the âfirst syncâ of a new device, which may take literally days to complete.
I want to add a pair of questions to the table:
PS: Thanks for the job you do, even though Iâm talking here about an issue, the general experience with Syncthing is excellent
I doubt the number of copiers has any effect. Likely itâs just the overhead of handling a file, including fsyncing it. At times weâve had an option to disable that, and I donât honestly remember the current state, but itâs something you could search for.
There is still an option to disable fsync in advanced settings. Beware tho that might lead to data corruption if you abruptly lose power etc.
Hi, thanks for the answer.
I donât want to sacrifice data safety in any case, so that door is closed.
My point is more to see (or find) if there are new ways to explore.
Lets start explaining my use case: we have a kind of âclient-serverâ setup, where we have a main server with all the shared folders set to âReceive onlyâ, and each client has only 1 shared folders on the client side.
From other posts, I read that one of the problems of delaying/disabling the fsync per file is that if the register of the file is written in the DB but then while the file is being written to the disk there is a power outage, the DB has the file reference but not the file in the FS, so it may think that the file has been deleted and spread the deletion to clients.
However, if this is correct, what if the DB register is written after the file being written to the disk? and if this is done in bulks when handling small files? I.e.: if syncthing node see that it has to receive 100 files of 1KB, do this steps:
1.- receive all of them write them to the disk (no fsync yet)
2.- fsync the files
3.- write to the db
4.- if everything is correct go again to step 1.
If a power outage happens during this process, in the worst case weâll have a bunch of (maybe) corrupted files from step 2, isnât it?
An option would be: if we can have control while a bulk transfer if happening, we can know which files were involved in that transfer and consider them âuntrustyâ after the node is restarted. (i.e.: deleting those (or their rests) and requesting them again to the other nodes.
Somehow we need to do the whole bulk operation transactional, we need to set a register when it start, know what needs to be transmitted, know when everything is finished ok. If any of those fails, on each syncthing start we should check if any transaction happen to not finish and cleanup the disaster.
Pre-apologizes if Iâm saying something totally wrong or that you have already discussed. Iâve read a lot in the forum but maybe I missed a concrete post where this was already commented
Is it clear that this will help significantly, or even at all? I donât think thereâs anything fundamental blocking us from batching up fsyncing. However in the end it will still be one fsync operation per file, which is likely still slow.
Isnât there an alternative to fsync for all the files instead of file by file? I mean, in linux you can simply run âsyncâ on the command line and that will sync all pending writes to the disk
No, Iâm not sure about it, and I donât have the skills to implement a test for it quickly. However, if the current option of disabling fsync increase the performance, and itâs possible to do a sync for all pending writes and not just per file, it would be a performance improvement for sure.
Another thought about this: even if there is a fsync operation per file, and this takes time, all the info is already received on its side. Unless there is a power outage or other situation where the transaction is broken and the data need to be considered untrusty, the sender doesnât need to send the data again.
I am not questioning fsync being slow, just asking if batching fsyncs helps. Calling sync on a file is supported by goâs os package, but thereâs no sync. Weâd have to implement that for all platforms, if it even exists outside of linux. Plus it has the disadvantage that it will flush everything, i.e. potentially writes not related to Syncthing.
Also I think itâs not really about data loss per se, itâs that our state written to disk should match the state recorded in the database, or weâll make incorrect decisions when starting up and potentially undo recent file changes.
We try to ensure this by fsync of changes to disk in close proximity to committing the change to database. We can delay the fsync but then thereâs a potentially long time when the database is ahead of reality if thereâs a crash.
Also none of this is compelling to me for a âfirst sync with lots of tiny filesâ use case. Yeah it takes a while, but itâs only one time for the lifetime of the setup. Itâll be done probably before weâve finished talking about it, certainly before any patch is deployed, and then itâs a non problem.
If you still feel itâs an actual problem you can disable fsync for the duration of the initial sync and then enable it again. Also makes it a non problem.
The problem is that fsync on different filesystems does different things.
I think fsync(file) on ext4 effectively is sync (sync whole drive).
There is fsyncdata which you can call in different modes (async after each block write, sync on file close), but you still need to fsync the directory in which the file is created, leading to the same problem.
Answer to imsodin:
As I said before, if the worst case is running all the fsync after a batch of files has been received, that would be an improvement already.
In the worst case: power outage, data corruption, etc. the action will be to re-request the data. And thatâs not that bad IMO.
Is that a disadvantage? why?
Answer to calmh:
I agree with that approach for single files, Iâm just suggesting that could be handle in a different way if a âbatch of filesâ transactional sync is done, as explained in one of my comments above.
The objective is the same, that the change in the DB and the write to the disk are consistent. You just need to control in parallel which files in the bulk transaction has been written and committed to both, if you can do all transaction ok, is fine. If not, re-request the data.
A while is literally days, and not 2 days, the initial sync of my files (1.7M files - 163GB) took around 2 weeks to be fully completed. Consider that weâre talking about a office server and the people is just connected on working hours. And I donât consider that my repo of files is bigâŠmost files are less than 64kb
Itâs not either the first day only, if I add a bunch of files (Imagine a project files repo, that can have a range of thousand files) it will also take a long while till everything is there.
Donât misunderstand me. Iâm not opening this discussion to know that I can handle it with workarounds. My intention was more try to contribute within my possibilities with my user experience. I think itâs an excellent tool, and concretely this matter of long sync of tiny files is not an uncommon issue in the community.
Answer to AudriusButkevicius:
My use cases are on both EXT4 and BTRFS
At the end, there is a point where all agree: fsync, fsyncdata or sync is required. Then maybe the option is try to minimize the number of times we call it in the safest way possible.
We call it once per file now, how can you minimise it even more? The only way to minise it is not call it.
My initial proposal is (on high level):
1.- Start a âtransactionâ: create the transaction register in the DB and the list of files related to that transaction.
2.- Receive n number of files (let say 100, 1000, whatever, fixed value, or dynamically calculated depending on the number of files + size)
Note: Once all the files are received, the sender is not needed anymore
3.- Run fsync for all files (this will take time but the sender can be gone for now, we donât need him).
Note: if 3 can be improved instead of fsync per single file but other way, even better.
4.- Write in the DB the required registers for all the received files
5.- Mark the transaction as done
If, during this process, you have an issue (i.e.: power outage, process killed, whatever), then, when syncthing is restarted will detect a transaction unfinished, then it has to cleanup the garbage (all the files related to the transaction of the pieces of them, registers in DB if any, etc) and re-request the info.
Itâs just an idea, if itâs not feasible technically then we leave it on a side. Edit: However I really think this is a point where any new ideas of how to improve it are welcome
Running fsync for all files will take the same amount of time.
Well, thatâs the second part of this, as I said, the preferable option would be to have a single âsyncâ to disk and not per file.
But that can come later, and the bulk transaction method will be already there.
And, assuming that the only option is a fsync per file, then you have the advantage that you can receive big sets of info from the sender in less time and leave him less occupied while you do the sync on the receiver side.
I.e.: if you calculate the n number of files to receive dynamically based on the file size, you can receive a chunk of tens of thousands of small files in a moment.
I just run a test in my setup, with disableFsync, and 1k files (small files - 1kb). I received all in 2 seconds and then the manual sync (from command line) took nothing, not even a second.
If I do it in the normal way it takes at least 100 times more (didnât measure the exact time, I can do it if you want anyway).
The bulk transaction part is already there. The bulk sync is not posix, does not exist on some platforms, and does not work on some filesystems.
Is there in the latest version? how can I give it a try?
