inconsistent "insufficient space" percentages on same filesystem
I’m getting insufficient space on disk for database on several folders, but they are showing different percentages even though they are on the same filesystem:
2025-04-12 11:26:10: Error on folder "MP3" (MP3): insufficient space on disk for database (/Users/john/Library/Application Support/Syncthing/index-v0.14.0.db): current 1.00 % < required 1 %
2025-04-12 11:28:55: Error on folder "Suandjhon Downloads" (Suandjhon-Downloads): insufficient space on disk for database (/Users/john/Library/Application Support/Syncthing/index-v0.14.0.db): current 0.53 % < required 1 %
2025-04-12 11:40:21: Error on folder "Suandjhon Documents" (Suandjhon-Documents): insufficient space on disk for database (/Users/john/Library/Application Support/Syncthing/index-v0.14.0.db): current 0.66 % < required 1 %
Syncthing v1.23.5, macOS (64-bit Intel/AMD)
% df -h
Filesystem                   Size   Used  Avail Capacity iused    ifree %iused  Mounted on
/dev/disk1s5s1              852Gi   14Gi  5.6Gi    72%  502388 58636560    1%   /
devfs                       231Ki  231Ki    0Bi   100%     798        0  100%   /dev
/dev/disk1s4                852Gi  9.0Gi  5.6Gi    62%      10 58636560    0%   /System/Volumes/VM
/dev/disk1s2                852Gi  379Mi  5.6Gi     7%    1989 58636560    0%   /System/Volumes/Preboot
/dev/disk1s6                852Gi  3.3Mi  5.6Gi     1%      20 58636560    0%   /System/Volumes/Update
/dev/disk1s1                852Gi  821Gi  5.6Gi   100% 1476896 58636560    2%   /System/Volumes/Data
/dev/disk1s7                852Gi  100Mi  5.6Gi     2%    7648 58636560    0%   /Volumes/APFS-CIS
map auto_home                 0Bi    0Bi    0Bi   100%       0        0  100%   /System/Volumes/Data/home
/dev/disk1s3                852Gi  1.0Gi  5.6Gi    16%      87 58636560    0%   /Volumes/Recovery
/Users/john/.my/.cfs/keys   852Gi  846Gi  5.6Gi   100% 1476896 58636560    2%   /Users/john/.my/.decfs/keys
/Users/john/.my/.cfs/other  852Gi  846Gi  5.6Gi   100% 1476896 58636560    2%   /Users/john/.my/.decfs/other
Am I misunderstanding what the “insufficient space on disk for database” percentages refer to or could this be a bug?
Sure could be; macOS does so many funky things with reported disk space it’s hard to tell. Also, the log entries are from different times, and these things change over time. :person_shrugging:
So the %ages should all be the same for shares on the same filesystem? It did seem later to settle down to the same %age for each so I guess it was still eating up disk space between one notification and the next, although in the snippet I posted the space %age wasn’t monotonically decreasing, which puzzled me. Thanks for the prompt reply.
