Impossible to upgrade since 2.1.5
Hi, I have two syncthing instances - which have been working for years - on two different servers, which I tried to classically update, from 2.1.3 to 2.1.5 or 2.1.6. I was unable to access them.
  • systemctl status syncthing@syncthing doesn’t give me anything wrong,
  • they are behind caddy (2.11.4) with the usual
    reverse_proxy http://localhost:8384 {
      header_up Host {upstream_hostport}
  • downgrading them to 2.1.3 is fine!
Any idea, any help would be welcome! Thanks
You’re going to have to get logs from systemd to see what’s going on and why it isn’t running.
You need to read again :slight_smile: I wrote I cannot access them! They seem to be running pretty fine, but not going through caddy reverse proxy.
You did write about the systemd status, so you can look at that. And the logs should be request from systemd, not from the running Syncthing instance.
