Images CreateFile \\?\
Hello,
I have a problem for which I haven’t been able to find a solution in the forum. I keep getting the error message shown below. There’s neither an error code nor any information about the affected data. I’ve already deleted and recreated the data.
Change monitoring failed for the following folders. This will be retried every minute, which may resolve the errors soon. If they persist, try to resolve the underlying problem and ask for help if needed. Support
Images Internal CreateFile \\?\G:\Images\Martin\Mobile\Images Internal: The system cannot find the file specified.
Images CreateFile \\?\G:\Images\Martin\Mobile\Images: The system cannot find the file specified.
The problem persists. What can I do?
What OS are you running? What version of Syncthing? Please post a screenshot of your Syncthing GUI, with the Folder in question expanded.
Additionally, what is G:? USB disk, network storage, DVD-RW, WebDAV over VPN, …?
It’s Windows 10 and Android.
I deleted everything on my phone and reinstalled it.
Now there’s only the Syncthing fork app, but it works with that.
If I’ve read correctly, it’s not quite the original app.
What you’ve written doesn’t really clear things up any more than we already knew before :sweat_smile:. If you could post some screenshots with the error messages and also the whole Syncthing Web GUI, that would help a lot.
