The “symbolic links” talked about here have nothing to do with files whose name ends in .lnk. So no, you should not remove those ignore patterns if you still need these files to be filtered.
These are two completely different things. On Windows, you can create symbolic links e.g. with mklink from the command line. If you’re not sure what they are though, then you also likely don’t need them .
