I have a folder syncing setup for only .mkv .avi and .mp4 files. Using my ignore patterns (given to me by a member of reddit) how would I tell it to also check sub directories?
Example:
F:\Complete\ is the sync folder. Need it to check F:\Complete\dir1\dir2
You can’t “search”, you have to explicitly know where the files are or invert the ignores and ignore all other extensions apart from the ones you are interested in.
