I Started Using Syncthing for a Folder I Always Forgot to Copy to FygoOS
I keep an active projects folder on my laptop. For a while, I copied it to my FygoOS NAS manually whenever I remembered. The problem was that I usually remembered only after making several important changes, and sometimes the NAS copy was already weeks behind.
To avoid relying on my memory, I decided to use Syncthing. I installed it on the laptop, ran another instance on the FygoOS NAS, and connected the two devices. I shared only the projects folder rather than synchronizing everything on the computer.
Now, when I add or update a file on the laptop, the corresponding folder on the NAS is updated automatically. I can also open the same files from another computer without first checking whether I copied the latest version.
I initially thought of this as a backup, but that is not quite accurate. If I delete or overwrite a file, Syncthing can pass that change to the NAS as well. I still keep a separate backup and am considering enabling file versioning for the synchronized folder.
Even so, Syncthing has been useful for keeping a working folder available on both the laptop and the NAS without a weekly copying routine.
For people using Syncthing with a NAS, do you rely on its file versioning, NAS snapshots, or a separate backup for older copies?
I don’t have a NAS, but I do something similar. I use an older PC that has a ton of storage on it and an unlimited cloud backup subscription. I use Syncthing to sync files to it for backup. If a mistaken delete propagates, I can recover from the cloud service.
I do the same kind of thing with one active folder I used to copy by hand, and the automatic sync removed a small weekly chore I kept forgetting. I also keep a separate backup, since sync alone would copy a bad delete just as fast as a good change.
I use file versioning mainly as a safety net for accidental deletes, not as a backup. I still keep a separate backup, since sync can pass a deletion along just like any other change.
